Multiple Drivers
Discussion in 'Model S: User Interface' started by willcasp, Jun 20, 2016.
  1. willcasp
    willcasp Member
    Bothell, WA
    First time poster, waiting for my new Model S which is currently slated for "late June/July" delivery.
    I can't seem to find documentation on how the interface for the car handles multiple drivers. Will the car save settings specifically for each driver? Is it tied to the key fob? The scenerio is that my wife or I will be driving the car. Primarily me. I expect that we will have different opinions on just about every setting. Will the car automatically adjust the UI or settings for whoever is driving the car?
  2. Chickenlittle
    Chickenlittle Active Member
    Virginia
    Yes 3 possible profiles
  3. Boatguy
    Boatguy Member
    SF Bay Area
    Yes, it will keep three profiles, but no it will not automatically switch them. They are not tied to the key fobs. You will need to manually select your profile from the top of the CID if you were not the previous driver.
    My wife is about 5' 5" and I'm 6' 1". After she drives the car, I can barely squeeze behind the wheel to select my profile.
    Very annoying, the profiles should be synced to the fob!
  4. DaveVa
    DaveVa Sig Perf #236 VIN #484
    Northern Virginia
    The Model S allows multiple profiles (not sure the limit, but we have 4 set). The profiles control a pretty large number of settings including the normal, side mirrors, seats, steering wheel, and a few that are more esoteric (e.g. creep mode). You can find out what settings are saved through the touch screen. It is not tied to the key fob, you select a name from the touch screen to change the profile. It also will not automatically do an "exit" profile like some cars that raise the steering wheel out of the way when putting the car in park. Finally there is also a restricted "Valet" profile that can be selected to limit performance when you give your car to a parking attendant.
    • Informative x 2
  5. willcasp
    willcasp Member
    Bothell, WA
    Thanks for the info. I find the surprising, as my GMC truck can do this! Unlock with a FOB, and the settings adjust for that user. I am looking through the REST documentation out there, and not seeing an option to set it there either. Will see how successful I will be at asking the wife to hit my setting button when she exits. I have a similar problem, can't get into the car after she adjusts it!
  6. paperjohn
    paperjohn Member
    Santa Cruz Mountains, CA
    Create your own exit profile. Move the seat, move the steering wheel. to a comfortable exit, entrance profile and name it "EXIT".
  7. K Hall
    K Hall Member
    Kansas City
    We have 5 profiles in our Teslas. 5 drivers 4 different cars.
    I sit with my legs out to switch from my wife's setting to mine. It is uncomfortable but can be done.
  8. SDRick
    SDRick Member
    SD CA United States
    How do you set more than 3 profiles? Mine only goes up to 3.
  9. K Hall
    K Hall Member
    Kansas City
    Have 5 and can add a 6 one if we need it. All 3 of our Model S's are from early 2103. I have a new one delivering next week. I'll let you know if it has a different setting.
  10. Boatguy
    Boatguy Member
    SF Bay Area
    Same problem here. The profiles should be tied to the fob!
  11. Sugacookie
    Sugacookie Member
    Bay Area, CA
    Do the profiles save Bluetooth phone info?
    For example I have my profile activated it will also connect my phone (even if my wife is in the car)
    And when my wife's profile is activated her phone is the main Bluetooth device.
  12. K Hall
    K Hall Member
    Kansas City
    They do connect with the phone
  13. Boatguy
    Boatguy Member
    SF Bay Area
    They do? My experience seems to be first connected get's the Tesla. If my wife an I both get into the car, it's pretty random who's phone will be connected to the car.
  14. K Hall
    K Hall Member
    Kansas City
    Could be that the driver usually gets in first
  15. gerti
    gerti Member
    Minnetonka, MN
    Profile handling could stand many improvements, like profile switching based on fob, store/recall audio settings (EQ, what media is playing, position etc), when two different fobs are detected also unlock the passenger door, what phone to connect to (as mentioned above)... And a number of other things that are escaping me right now. It has seen refinements in some updates though, so there is hope.
