I have a 2013, long since out of warranty with plenty of issues that were fixed and are no more. I have over 100k miles on it, and a 3x drivetrain replacement. I suggest you look into what it means to have a lemon, ACTUALLY have a lemon, not have an early model car with quality issues. I have been frustrated with Tesla as much as I have been delighted with them. Same as any car manufacturer...
Here's the list of your issues, some of which I've had too, several times over:
* Problems with the sunroof, several trips -
known and common. SVC has a fix, several trips? was this before they developed a fix?
* Door seals -
i have door seal issues as well, but what does it mean to have "issues" here?
* DC to DC, converter -
not common, im sure it was fixed promptly right?
* Bubbles in the display -
common, fixed under warranty i assume? they've since developed a much cheaper fix if you were out of warranty
* Hatch leaking to the point the locking motor was submerged and now it makes noises, that they won't replace it. -
a motor makes noises? isnt that normal?
* Several rattles, that still aren't fixed -
rattles in pre 2014s are pretty common. I've got them too, your car is almost 4 years old now...
* Charge port light ring LEDs -
very common, and easily fixed
* Door wind regulator -
happens on alot of cars, did they fix it? did it happen again?
* Liftgate -
what about it?
* Glovebox latch broken -
sounds like wear and tear but ill give you this one, assume they fixed it as well?
* Noisy AC -
all the AC's are noisy, there's a "fix" to wrap it with some sound proofing around the compressor. consider that since you have no engine noise like in an ICE so you'll hear that kinda stuff more.
* Plastic piece on steering wheel broke and I had to call corporate, because the local repair center would not fix it -
thats weird, you can keep this one, hope they fixed it?
* Panoramic sun roof opens by itself, from time to time. This was never fixed. -
i can only chuckle at this sorry
* 12V battery went bad -
model s eats 12v batteries every 2ish years
* Noisy windshield wipers. Still not fixed -
this is normal
* Rear seat squeaked -
build quality, fixed in later cars
* Rear headrest foam collapsed -
what does this mean exactly?
* Door handle assembly needed to be replaced -
very common, fixed under warranty... i even got a goodwill out of warranty once
Thank you for you reply. I was hoping TESLA would do something for me, since the warranty is close to expiring and I have had so many problems, like throw in an extended warranty at no additional charge. It's been my experience that it is not usually worth buying an extended warranty, because most cars don't have a lot of issues, but this one does.
I think under the circumstances, it would be reasonable for them to throw in an extended warranty, don't you?
