Hey all! I took delivery of my M3LR a week ago and got a chance yesterday to play around with TACC. Some of the behavior was unexpected, and I frankly don't know if it's due to my inexperience with the feature or if what I thought made sense to me isn't quite how the car is programmed. Figured I'd just ask y'all to try to recalibrate my expectations.
Here's what happened.
In my Autopilot settings, I believe I have things set to set my speed to the posted Speed Limit +7, and it appeared to work just fine.... I was in a 60 MPH zone (the car knew it) on a divided highway, two lanes in both directions, and was doing 63 when I engaged TACC. The car set itself to 67 and accelerated gently to that speed. It slowed when approaching slower traffic, resumed at 67 when it was safe to do so. Okay, that works.
I entered a section of highway where the speed limit dropped to 55 MPH. The car knew it, having seen the speed limit sign and displaying it on the screen. But the car did not slow. I had expected a deceleration to 62 MPH but instead it maintained 67. I gave it a few seconds to confirm it wasn't going to slow, then manually scrolled the set speed down to 62 using the right thumbwheel.... which of course meant now that I had manually selected my speed it was likely going to ignore the Speed Limit + 7 value in the Set Speed portion of the Autopilot settings screen.... which is what happened.
To get the car to drive Limit + 7, I had to disengage and reengage TACC.... but once set it would never update if/when the Speed Limit changed. Is that's what's SUPPOSED to happen and my expectations are too high, or am I doing something wrong here?
Additionally - and I'm more than willing to admit my own ignorance here - but while driving under TACC I *thought* I was able to command a lane change by using the turn signal. I know that FSD does that automatically and I suspect it will do it on command, but I honestly thought regular Autopilot included this feature. Same question as above - am I expecting something that's not part of the software or am I doing something wrong?
I've attached screencaps of my Autopilot settings.
I am on factory/delivery software version 2022.3.101.1, having just had the car added to the "Fleet" and not having had it long enough to be included in a standard OTA yet. The only OTA I've received was the upgrade from 2022.3.101 to 2022.3.101.1.
