Jerry,
Camber may be a non-wearing angle but common sense would seem to indicate that, if you are not loading the outside edge due to high camber and low compliance, you will tend to wear the remaining portion of the tire.
No disagreement there. "Considered to be a non-wearing angle" isn't the same thing as actually being a non-wearing angle. When tire aspect ratios were much higher, it took a lot of poor alignment to get "camber wear" and as the aspect ratio decreased over the years, the amount of variance from "perfect" to get good wear has become smaller.
My comments about FMVSS 126 were directed specifically at the emergency maneuver test where a steering machine is used to yank the wheel back and forth. Differential braking and other stability control tricks can do wonders for controlling certain issues (throttle lift on entry comes to mind) but is useless when you start talking about winding up a 4700 lb pendulum. You go about getting MS to wag its rear and it is going to take a bunch of camber in the rear so the car has something to roll over onto (as in, more patch). I believe all Tesla, MB, BMW, Audi and the like are using this trick to keep the car from swapping ends.
Agreed. There are other ways to accomplish this, but they are going to be more complex (and expensive). Adding negative camber is the least expensive and most straight forward way because there isn't a lot of redesign required.
Lastly, something is going on here as the informal tire survey shows people getting everything from 4000 to 15000 and more out of 21" tires. There does not seem to be a correlation between wear and driving styles, or at least none that jumps out at you. A wild guess on my part would be toe as this is the only thing that is adjustable in the rear. Regretfully, there is no easy way to gather data on toe v. wear as I can not imagine everyone is going to measure wear and have the rear toe and thrust angle checked just for a survey.
Right. The camber merely accentuates any misalignment in toe. Wouldn't it be nice if the display showed the alignment angles?
- - - Updated - - -
Doesn't having to replace tires at under 10K miles seem counter productive to the whole less maintenance cost that an ICE? Not only are you paying a premium for an electric car, your tires won't eve last 1 year?
That's why there are two tire size options. I wish there were more.
