If this is to be expected for a 20 kw solar roof at my sunny location in northern CA, it is a bit disheartening that it can basically only handle my AC at this time of the year, no EV charging has been done. I "overbuilt" this system, they recommended a 16 kw system.
You mention you have 2 powerwall+. AFAIK, those inverters are 7.6 each. So, even if you have 20kW of panels, you only have 15.2 of inverters, so your system will never have a peak output of more than your inverters.
You also mention that the orientation is east / west, which isnt optimal (but not much you can do about the direction your home faces, etc). You will have less production during the fall / winter than someone who had the same system size but mostly oriented south.
Your yearly production will likely be fine and should be what you focus on, but you dont have any data to compare to, so its understandable that you are looking at it and trying to figure it out.
I really doubt that there is anything wrong with your system at this point, but as this is fall, and production from PV systems are declining due to sun orientation (see @h2ofun 's post , his peak of 180 per day is down to 80 as an example), you wont really see how much your system can generate at peak output until next april / may.
