Welcome aboard, @alset. Your commute pattern sounds a lot like mine, including the frequent trips to Maine. What town in Maine (I'm in South Bristol)?
Checking in from Winchester, MA with a Performance model on order (gray paint, gray wheels) at P3886. I expect to drive to Cambridge daily for work (7 miles each way - may take detours via New Hampshire) and 150 miles each way to Maine many weekends.
Register on the map here if you haven't already:
World Map of Model S Reservation Holders
I spotted another Winchester, MA order on the map at P3963 - maybe they'll deliver both of us the same day? We're only 77 production spots apart, less than a day at full production speed with dropouts.
Have a day or two to decide one more way to save $1000: should I drop the paint armor? Could really use your input, New Englanders.
Pacific (metallic) Blue - my issue is do I need it, less than will that partially covered hood or slight yellowing look bad...thoughts? Never had it on a car.
If I was doing blue, I would likely get it. It was all but invisible, even on the white. It protects from rocks, etc... And I've read that the paint is "soft", so...
I have read that too, but not from any Model S owner. Where I think it came from is that the fibre-glass body of the Roadster required soft paint to keep from cracking. The metal body of the Model S should not require any such strategy. The half covered hood makes it a non-starter for me (even if I was getting dark colour).
...Dave was a big proponent of the paint armor up in New England, though. He confirmed others' POV that on dark colors, the paint armor would scarcely be visible. I certainly can see the argument for holding out for more extensive coverage, but if the exercise is to try to trim out cost for @ModelS1079, that's moving the wrong direction.
Robert, All - many thanks for revisiting this subject. Sounds like I need to either go with the Tesla Armor or promptly consider an aftermarket coverage of at least the hood/front, or just accept some deep dings. Heard one might be able to cover the headlights as well after market. Not sure that's worth it. I'd like to work on an estimate as cost is the issue at hand for me - any vendors you folks have used? Again, thanks for the feedback.
I have talked to these guys: Wheel DynamiX, Inc. because they're local to me.
I also may consider them for snow tire swapping, again since they're local and experienced with high end cars.
They quoted me $2,600 (or $2,700) for the whole car though so now I'm having 2nd thoughts.
