Did you do the math? Specifically, I'd like to see the simulations, for two full years of your energy use, using historical data of actual use, solar irradiance, and the smallest system solar and battery system required to ensure that all of your power and energy needs are met 99.9% of the time (utility level reliability).
This is not the level of reliability of the utility companies I've dealt with. 99.5%, maybe.
- - - Updated - - -
I'll bet you can't get off the grid for less than $10k.
Of course, I don't live in Arizona. It is *way* easier there.
- - - Updated - - -
Well... $5 is an average. It's $0.70/kWp
70 cents per installed kilowatt.
And the vicious utility company jackasses proposed 14 DOLLARS (correction: 8 dollars) per installed kilowatt.
This is even less acceptable. There is no justification for this whatsoever.
I can see a flat fee to charge for grid maintenance.
I can see a "peaking" charge for fluctuations in voltage.
I can see paying less for "excess solar" than the customer pays for grid power.
But THIS? This means that anyone considering installing a *large* solar array has a pretty strong incentive to go off-grid.
I don't think that's good, on the whole; it means people will oversize their systems and buy unnecessary batteries. Nobody wants to screw around with a rapacious utility company.
- - - Updated - - -
For reference, the last house I spent time in in Arizona left all the lights off at night. The water heater had a huge insulated tank which meant that it didn't run at night and merely saved hot water until morning.
If the house had been insulated appropriately, it would have used next to no energy at night.
It was designed to not heat up too much during the day by careful placement of windows.
*And the electric power company was unreliable*.
This was before the really high-efficiency solar panels were available. But going off-grid in a house like that now? Boy would it be tempting.
- - - Updated - - -
To be clear here, I'm looking at this from a particular perspective: that of the low-volume user who has capital. Once all the flat monthly fees start piling up, it stops making sense to pay for the grid *if you aren't using it very much anyway*. If you actually need more than trivial amounts of electricity at night, then you will certainly want to stay on the grid.
