Just reading the last few threads, it sounds like Tesla could have said something like: Produces 691 HP*
*based on ICE performance standards
edit: no, I guess not. It is only 691* in the 0-60 spec.
Yea, that's the funniest part of argument that those who say you can't compare EV vs ICE hp ratings. Why is it funny? Because they're *exactly* right but in the wrong direction.
Any EV car making x amount of hp will kill any ICE car that makes the same x horsepower at one peak. EV performance curves are so much more favorable because they make pretty much peak hp at all RPMs, not just one. The amount of power it takes to accelerate from speed S0 to S1 is determined by how much power is applied under the curve. ICE engines have to use gears to stay as close as possible to their peak but they still put down lower power than their peak on either side of that peak as they accelerate through gears. Having to change gears takes even more time even with a DCT or equivalent.
The EV car doesn't have to make as much *peak * hp have the same acceleration performance as an ICE car because it's average hp applied under the acceleration curve is more for the same peak hp.
The problem here is the P85D makes so much less power than what is claimed that it's still not good enough to compete with ICE cars that have way less power once those ICE cars are already in their power band.
The P85D kills most cars from 0-60 but not because it comes close to making it's claimed 691 hp but because the power it does make it make *very* early.
You can't use a an ET calculator to calculate ET for an EV vehicle because those calculators assume typical power curves for ICE cars. There is no curve for EV cars. The curve is flat(mostly).
If you take the P85D off insane mode and leave it in sport, it will still make the same amount hp but it just does so later. Instead of hitting peak at 36 MPH, it hits peak at 60 MPH yet the ET is now 9 tenths of a second longer.
Watch all those drag race videos on youtube with P85Ds racing other cars that have worse power to weight ratios. The P85D always comes out swinging. Then after a few seconds, you almost always see the ICE starting to close the gap because it's accelerating faster than the P85D now. Sometimes the P85D still exits sooner but even in those cases, look at the slips posted at the end of each video. The ICE car with the way worse power to weight ratio always has a much higher speed. The P85D when it wins only wins because of the head start it got from 0-30 MPH which is usually considerable.
Just look at this acceleration chart over time between a P85D and a Hellcat.
The P85D weighs 10% more but the Hellcat's acceleration force is 50% to 60% more for most of this chart except the very beginning because we all know electric motors can produce all of their torque at 0 RPMs.
- - - Updated - - -
Like most people in this thread I am a car guy (and motorcycle guy). I have had this happen with Cobra Mustangs (under rated and required new exhaust) - Mazda RX8 that actually was bought back by Mazda because it didn't meet HP figures. Not to mention my Yamaha R6 that never hit the 17,000 rpm redline...
At least Tesla hit the 0-60 numbers. Hopefully Tesla learned a lesson and my P90D will be closer to the horsepower I want.
Mazda had a class action suite filed against them for overstating the hp on the RX8 by a *mere* 10hp. Most manufacturers understate their hp. Tesla did for the S85 and P85. The S85 is stated as 362 hp but an S85 at 90% dynos 375 rear wheel hp. The P85 was listed at 416 before before they revised it to 472. But since a P85 dynos at 430 to 436 at the wheels, it's still understated even now.
- - - Updated - - -
According to posts in this thread and elsewhere, the problem is that when people found this out during a test drive, they were told by Tesla staff that this is because the test drive vehicle is speed limited to 80 mph and power tapers off before reaching that limit. They were not told that this is simply the characteristic behaviour of the vehicle even if it wasn't speed-limited.
I was one of those that was told this on my test drive. It was limited to 80 MPH and I was told that because of this, power was tapered off long before this so that there wouldn't be a sudden decrease in acceleration. If anyone has ever hit the rev limiter in a fast car at speed, you know what I'm talking about
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
