The car comes with a mobile charger that many people find sufficient. This mobile charger works with a variety of plug adapters, purchased separately from Tesla. The adapter for a standard wall outlet comes with the mobile charger but charging from a standard wall outlet is way too slow for most uses. The adapter most commonly used is a NEMA 14-50, which is what most kitchens have for a cooktop range/oven. Simply buying a 14-50 adapter from Tesla and having an electrician install a 14-50 outlet in their garage is what most people do.
That said, many people buy the dedicated Tesla wall connector (also called a wall charger, even though the charger is technically inside the car). The wall connector is more robust, looks nice, and having one means that you can leave your mobile charger in the car, which many people like.
I should have clarified that we have 240v in the garage. At the moment it's just a junction box, not an outlet. My wife will likely get an EV next year, though probably not a Tesla. Is there a reason to wire her side of the garage at the same time as mine?
Speaking of the Tesla vehicle alone, do you gain anything by going to Clipper Creek or to other brands instead of the Tesla charger?
Robert,
It's more of a pain to use a non-Tesla charger (like Clipper Creek or Chargepoint). The reason is because A) you have to use the J1772 adapter (which means you'll probably want to buy a 2nd one to leave attached to your home charger so you can keep the other in the car), and B) the J1772 chargers don't have the release button in the handle like Tesla chargers do. This means you'll have to use your App to release the cable from the charge port (or go inside the car and press the release button on the touchscreen). This will be annoying if you have to do this every time you leave the house.
Also, if/when you add a 2nd EV, it's unlikely you'll need two chargers. Will you each be driving 200+ miles per day? If not, sharing a single charger will be fine. Most of them come with ~20 foot cables anyway so it'll reach across the garage regardless of where you install it. If you do get into the odd mileage crunch then I'm sure there's a Supercharger nearby where you can get a quick hit of juice.
BTW, you can buy an adapter that lets you charge a non-Tesla from a Tesla charger. You could get a Tesla Wall Connector now and then one of these later on:
https://www.amazon.com/Lectron-Tesl...rds=J1772+tesla+adapter&qid=1607382458&sr=8-6
Andrew (former bimmerfester)
My chargepoint charger came with a $500 rebate from my electric company. Then they gave me a $50 check for registering it with them so they could bill me based on use. Then they give me half off electric if I use it between 11pm and 6am. The Tesla charger does not do this.
If I didn't get this deal I would just use the mobile connector and a nema 14-50 outlet.
Robert,
I have the ChargePoint HomeFlex and I do not have to do this. Mind you, I do have to open the driver door, but then pressing the button on the HomeFlex handle releases it from the Tesla charge port no problem. I grab the adapter, press the button and then pull both out together. Maybe it's an improvement ChargePoint made?
You sound like you're from around my parts, but not completely. PSEGLI gave me $500 plus the $50, however I only get 5 cents off per kWh for overnight charging.
I already has a Tesla wall connector, but I like the fact I can actually see the cost that charging through the ChargePoint gives me. I got the ChargePoint because of the almost free charger based on above, plus the wife will probably get an EV, and most likely not Tesla. She like being high off the road in a crossover and the Model Y wasn't to her liking.
I am on Long Island. Our electric bills are a scam. It's around half off of the electric cost but we pay a bunch of fees. Our electric company likes to claim we have lower electric rates than others but after all our fees we pay significantly more.
I don't like the Y either it's not an suv it's a model 3 hatchback. They raised the roof and put the seats on stands. Literally they are on risers.
There are some companies coming out with SUV's soon. GM looks promising.
Energy Charge: (per kWh)
First 250 kWh: Standard $0.0827 $0.0827
Excess 250 kWh $0.1045 $0.0827
