dhanson865
You should be aware that 2014 and newer leafs have a different battery chemistry that improves on life of battery in extreme hot temperatures. All replacement batteries will have this chemistry so if you run into increased degradation and get warranty replacement will be new chemistry. I took advantage of rapid depreciation too. Country views battery cars as toxic so rapid price decrease. It will decrease your depreciation and price if you get a used one
You should be aware that 2015 and newer leafs have a different battery chemistry that improves on life of battery in extreme hot temperatures according to Nissan.
I'm not sure why you picked 2014 for that.
If you don't believe me check out Update on Nissan LEAF Battery Replacement - My Nissan Leaf Forum where Brian Brockman of Nissan first announced the chemistry change. Anything you saw about 2013 or 2014 packs before that was wishful thinking.
We are now seeing degradation in 2013 packs this summer and will have a stronger data set next summer. It'll be two more summers to have strong data on the 2014 packs and three more summers to have any data on 2015 packs. So if you want you have time to pick any article you want and argue that source X said 2013 and source Y said 2014.
But no matter what source you choose, Nissan claims the chemistry change helps with the heat issue. There still is no active cooling on the Leaf and we won't know for several years if their change in chemistry helped as much as they wanted it to. Check http://www.electricvehiclewiki.com/?title=Real_World_Battery_Capacity_Loss in 2018 and see if it holds up.
