Great Job!!
The first pic looks like you took seats and rails out entirely ..... is it all metric?
So aside from the satisfaction was it worthwhile??? If so I'm driving out to VT
I did Sound II *Plus*over the weekend with the help of the soundproofing expert here on TMC - dhrivnak. I was concerned about weight so I used the Superlight Dynamat material and in addition I lined the whole tub - basically everywhere there was carpet with Bonded Logic sound insulating material. It's a great insulator and sound absorber. Also very light. Maybe Dave will post some pics. He was really nice to help me - saved me a lot of time and prevented me from making a lot of mistakes.
I am taking your advice and will add soundproofing while my seats are out. The floor seemed pretty straight forward, but the doors seem much more challenging. Do you recommend breaking through the plastic and putting Dynamat on the inside of the outer door panel? How in the world did you get the Dynamat on the upper part of the door? There's a metal bar going all the way across the door. Did you also Dynamat the outside of the plastic area? Thanks much!
HC did you try this on the hard top? Roadster Squeaks & RattlesNow if we can just get rid of the squeaking hard top for more than a month at a time...
Yes I tried new foam over the roll bar and felt in the front and the foam helped but not the felt. I also replace the 3M anti-friction strip of tape that I put on the underside of the hard top where it meets the gasket seal on the car. But after about a month all the squeaks come back again.HC did you try this on the hard top? Roadster Squeaks & Rattles
It's HCSharps fault!
Well i had to apply some of that additional sound proofing from HCSharp's project to my car after I got back. So out comes the seat for some additional sound proofing. You can see the Dynamat poking around the carpeting and I added the sound absorption under the seat. Hopefully I can also run the heater a bit less in the winter.
It has been quite a while so I can’t recall. I am guessing 45 sqft for the full tub Including under seats, and I added some inside the doors and the lower belly pan as well. So probably about 60sqft on my car.How much dynamat would you recommend buying to do the entire project? I need to take out my seats to redo them anyways and thought I should do this as well while they're out!
