Do you have such troubles?
When you're driving down the road in a Tesla, wind noise annoys you which makes it hard to concentrate, especially on the highway.And it didn't take long for the car to be washed, and the car was full of dust...
Why is Tesla's wind noise so loud?
After our research and testing, we found the main reason was that Tesla has a large glass roof, and the doors have no seals. This results in Tesla's wind noise being a bit louder than other cars. This is also the reason for the accumulation of dust.But how do reduce wind noise and dust for your Tesla?
Our research found that turbulence generated during vehicle driving is the root cause of wind noise. During the high-speed driving of the vehicle, periodic airflow separation occurs in a specific part of the vehicle body. Wind noise can be radically reduced by using seals to block noise while avoiding the separation of the airflow and disturbing periodic wakes.To solve this issue, BASEHOR designed a door seal kit for Tesla.
Does it really work?
YouTuber Tesla Tips by MTN Ranger make a video to test if the wind noise reduction kit is really effective in reducing noise. It was found that driving on local roads reduced noise from 64dB A to 56dB A, and on the highway from 73dB A to 66dB A. (YouTube Video Link)For those unfamiliar with the decibel scale, reducing the sound level from 73 decibels to 66 decibels may not seem dramatic. But we need to know that a decibel is a logarithmic unit, so the noise reduction from 64dB to 56dB is about 55%!
This means that the wind noise reduction kit does have a significant effect on reducing noise.
The BASENOR functions of the sealing strip
BASENOR Door seal kit made from EPDM expandable hollowed sponge rubber. It can enhance the tightness of the door, sound insulation, and noise reduction, improve the cooling effect of the air conditioner in the cab, reduce driving wind noise and provide a quiet driving environment for your Tesla. At the same time, it can also play the role of waterproof, dustproof, heat insulation, and so on.If you want to make your Tesla more refined and comfortable, BASENOR Wind Noise Reduction Kit is a worthy investment.
Click to learn more:
