I have a question and can’t seem to find what the issue is, short of taking it back to the place I that helped me install the nvx sub and amp.
The issue started when I had the MCU died on me. When I took it in to have them look and recover the MCU1, the amp stopped to work. They then upgraded to MCU2 and the amp still has no power to it.
I opened the frunk and saw the amp power is connected to the 12V battery. I checked the NVX fuse box connected to the 12V battery abs the fuse looks intact. At the amp, when I use a power meter to it, I get no signal. At the passenger door, I removed the floor panel below the Tesla door guard and don’t see and disconnect.
Is there something supposed to connect to the back of the MCU that was not connected?
I can’t figure out where else to check where the power is loss from.
it’s a 2015 MS.
suggestion?
Thanks.
it’s a 2015 MS.
suggestion?
Thanks.
