Octopus Energy Saving Sessions
Does anyone know how the Octopus ”Power Hour” energy saving sessions are actually calculated?
I’ve taken part in all of them, but the results just seem totally random.
I’ve had sessions where we’ve switched off as much as we can and gone out, only to be told that we didn’t manage to save anything.
Some sessions, we’ve made very small savings, Including one where virtually everything was switched off and the whole family was in another country.
One session I forgot it was happening despite signing up, only to be told I’d managed to save 93% of my normal usage and be credited with over £16 off!
I’ll continue to sign up for them and don’t really do it expecting to save much as we are already quite energy efficient. It all just seems so random.
Confirmed as £2.25 / kWh saved. 297 MW and 300 MW procured respectively of 350 MW requested.
Reactions: ACarneiro
Upvote 0
I feel your pain
charging couple of kwh @ 30p to discharge 3 kwh at £ 2.25 :D
Ok, I’m not saying I’m right, but see what you think of this logic.
Assuming you will have enough in the battery to last the whole savings session. Would it not be better to run out after and then use exactly the right amount of peak to 23:30 than to top up before with an unknown amount and perhaps “over buy”?
Of course that first point may not be true for you.
Upvote 0
This is what I do... but... you have no Blackout reserve should the worst happen.
Bit embarrassing, but hey ho...
I'm down to 5% battery on two Powerwalls right now, with nearly two hours to go...
Edit: in fact, I'm boosting it to 10% backup power, at peak rate, to give me some slack. It'll cost me 40p (having earned £11.25 in the savings session)
Reactions: phil4
Upvote 0
And In case you will not have enough to last full discharge session?
Reactions: phil4
Upvote 0
