So the install is complete today by noon. The installer have turn on the system for me. However it started generated only 1kw from my 19.2kw system. Installer says it’s the trees on my south side creating a large shade. It peaks at 3.6kw around 2pm and by 3:30 it dropped down to 1kw due to sunset. Is it the trees or is it something else?
Shading is a major issue this time of year. And with the sun so low the days are short even without shading.So the install is complete today by noon. The installer have turn on the system for me. However it started generated only 1kw from my 19.2kw system. Installer says it’s the trees on my south side creating a large shade. It peaks at 3.6kw around 2pm and by 3:30 it dropped down to 1kw due to sunset. Is it the trees or is it something else?
Yes I have about 20 panels face west 23 panels faceing east and 5 panels facing north. tilting 26 degree. There is 8 trees on my south side covering up all the sun during the wintertime which Im planning to get a tree guy to trim it, Hopefully that will help increase production during the winter months. My entire house is running off electric right now with brand new mitsubishi hyper heatpump and a new 24kw hot water heater. Plus my Model X plaid I dont think Ill ever have to worry about generate too much energy for my batterypacks to handle.If your installer said "trees" its probably trees (we would have zero way / information to speculate otherwise).
One thing I will tell you though, is for most of the US, the lowest amount of power you will generate on a clear, sunny day will be between the end of november and february.
You dont judge production by days, but by weeks (and months), so you may not want to hear this at all, but your half day production on a brand new system isnt really relevant as to what its going to produce or not.
If I was in your shoes I would probably test it tomorrow (all day) but I also would know that your 19.2kW system will likely never hit 19.2kW peak production, especially at any point in the winter (but likely not at any point, ever).
I also think thats a very large system for 2 powerwalls, so I am going to assume (and I realize that assuming is generally bad) that your system is spread all over on multiple roof planes / cardinal directions so your daily generation might be longer but the peak production lower.
If not, I hope you dont run into an issue if you were to test this system during the summer of it generating too much PV for your powerwalls to handle during a power outage.
thank you for that insight. The app shows me I generated 7.1kw today from 12:30pm turn on time to about 4pm sun set. Im just making sure that they have connected all my panels right.Shading is a major issue this time of year. And with the sun so low the days are short even without shading.
According to the Tesla app, my 12.75 kW roof generated 7.8 kWh today. Peaked at 1.8 kW today. Shading, some clouds, and winter solstice (Dec 21-shortest amount of daylight) all lead to low production for us. The same system does close to 55 kWh/day in early June when the sun is high, and the days are still relatively cool.
