Tropical Jack
You might want to consider running 6-2 w ground Romex, and using a 50 amp breaker. Then you could use the Wall Connector to charge at up to 40 amps. Running the Romex through the attic would be a lot more economical than a conduit run.
If you have an electrician do the job, please ask him to downsize your well pump 50 amp breaker. That is way too high an amperage circuit breaker for any well pump.
Jack
Jack
