Outside temperature way off
Discussion in 'Model S: Interior & Exterior' started by MacGreiner, Oct 1, 2017.
  1. MacGreiner
    MacGreiner Member
    MD
    I have just noticed that my outside ambient temperature is show 20-30 F higher than it should be. Any ideas as the where the sensor is located and if anyone else has had this issue?
  2. JHWJR
    JHWJR Member
    Pittsburgh PA
    I have. Usually when I try to get a temperature after the car has been driving a long way or just after supercharging. Both of these I attribute to warmth coming off the battery. It corrects itself over time or after a few miles on the road.
  3. David29
    David29 Supporting Member
    DEDHAM, MA
    Also, if it is parked in the sun, it will tend to show a temperature higher than the air temperature because the pavement heats up and in turn warms the sensor.
  4. MacGreiner
    MacGreiner Member
    MD
    This is when driving along at both local and highway speed. Doesn't seem to correct over time. Smells like something that needs a tech to look at by the looks.
  5. ahkahn
    ahkahn Member
    Chicagoland
    Yeah, mine has been all over the board.
  6. UnpluggedP
    UnpluggedP Vendor
    Hawthorne, CA
    Outside temp sensor (black and white clip) is located in the front bumper gap shown here. We have seen this issue occasionally. It seems that hot air can get trapped and it will read incorrectly. Removing the bumper and re-positioning the sensor slightly seems to work.
