Cabin Overheat Protection is for keeping your cabin temperature from getting too high when the car is parked outside in the sun. What does preconditioning have to do with that?For our 2022 M3LR, we have NEVER used the Cabin Overheat Protection. Since our car is a Daily Driver with pretty much the EXACT same time of departure, we have setup a Preconditioning routine under "Schedule" in the application. It took me a bit to figure this out when we first purchased but it literally works wonders! We have it set up to leave my wife's work and whether it is the winter or now summer, the car preconditions based upon the temp we have set.
It has a TON to do with that! In our situation, my wife leaves the Tesla parked at work. She gets in at 6 AM and leaves at 4 PM. The entire time she is at work with the car sitting she could really care less about the interior temps. When she is ready to leave, Preconditioning, sets up her "comfy temp" by the time she sits in the car.Cabin Overheat Protection is for keeping your cabin temperature from getting too high when the car is parked outside in the sun. What does preconditioning have to do with that?
If you're using Cabin Overheat Protection simply to make the car comfortable before you get in to drive, then yes, you can use preconditioning or just turn on the AC before you get in the car. If you're trying to protect the interior of the car and its contents from getting too hot when the car is parked, Cabin Overheat Protection is the way to go.It has a TON to do with that! In our situation, my wife leaves the Tesla parked at work. She gets in at 6 AM and leaves at 4 PM. The entire time she is at work with the car sitting she could really care less about the interior temps. When she is ready to leave, Preconditioning, sets up her "comfy temp" by the time she sits in the car.
If you feel that items in the car that need to be under the prescribed temp for Cabin Overheat Protection go for it.If you're using Cabin Overheat Protection simply to make the car comfortable before you get in to drive, then yes, you can use preconditioning or just turn on the AC before you get in the car. If you're trying to protect the interior of the car and its contents from getting too hot when the car is parked, Cabin Overheat Protection is the way to go.
I agree! Cabin Overheat is something that folks may want. We elect not to. I apologize for the argument @EVRider-FL@ColoradoMike: Nothing to agree or disagree on here. The OP created this thread because they were having trouble enabling Cabin Overheat Protection, and I tried to help them with that. Whether you think that feature is useful is besides the point, no one is telling you to use it.
Did COP actually turn on at some point? You should get a notification from the app when it does (unless you’ve disabled the notification). Also, I’m not sure if the interior temp displayed by the app is completely accurate.I had a similar situation the other day. COP was on with A/C enabled, but the temp climbed up into the 120s. I was able to cool it using Climate on the app, but COP didn't seem to be doing its thing.
Thank you, I have been wondering about this as well. I often see that my app shows the Tesla is at 100F, but once it goes over it says "Cabin overheat protection" as well. I was wondering that it didn't work as it allowed the car to be 100F. But now I understand that it pushes the temp down again to 100 after it reaches a temperature above the threshold.
- On: The air conditioning operates when the cabin temperature exceeds 105° F (40° C), or the selected temperature if available, on the touchscreen or mobile app. Customizing temperatures may require the most recent version of the mobile app.
Read the manual. Read all the conditions and see if you satisfy all of them:What temp is no ac cabin overheat protection supposed to kick on? 104?
Right now the app shows the cabin is 144 and the fans aren't running. The battery is almost fully charged.
That doesn't seem right to me.
Correct, you only get the temperature options if you’re using AC.The manual also doesn't explicitly state the temp that no ac turns on, but I'm assuming it triggers at 104 as well.
