Man, that Dodge driver really loves riding the rev limiter!!Have also ran high 10's. With my forged rims. I run high 10.9's. The tires are wider but rims much lighter.
With stock rims I get to the track about 90% and see 10.8's consistently. I really wish my track had somewhere to charge at the location. Maybe in the future.
Also lowering tire pressure to 32 will help.At this point, I don’t think I’ll ever beat a 10.83. Anything I’m not thinking of here or is the only thing left to do is remove weight?
And how did some pull 10.5’s around 125 that are posted on dragtimes.com and on YouTube? That 5mph higher trap speed is HUGE
Regarding rolling mass? I hook up with no tire spin but didn’t consider lowering psi for weightAlso lowering tire pressure to 32 will help.
Definitely a different mindset with these EVs!Yup cutting weight is the only option. Others have installed drag radials ect. Only to loose trap speed. Everything that we learned over the yeas racing ICE vehicles does not apply with electric. I would be interested to see if someone comes up with a cover for the front to reduce drag. That should help allot
It would give a little bit more grip. From watching many 1/4 mile races of Teslas, the fastest times seem to all have their tire pressure in the low to mid 30s.Regarding rolling mass? I hook up with no tire spin but didn’t consider lowering psi for weight
I know that track prep at least at Sacramento Raceway is poor at best so maybe that contributed to not so stellar times in my P100D shown above.So with that famous Motor Trend P100D that ran the 10.5 @125, what gives??!
You have to be in Max Battery Power mode, not necessarily with the batteries heated up all the way, but in the mode. Activate Ludicrous Plus (the Star Wars looking thing pops up on the screen and then asks if you’re ready and hit the “Yes bring it on”) and then even while the batteries are heating (not yet fully in LP mode) you can use launch control. Left foot hard on the brake and quickly fully depress the go pedal, “Launch Mode Enabled” shows on the dash, then push down the go pedal and hold (your left foot should have been hard on the brake the whole time) with your right foot, you’ll feel and hear the car getting ready; once you let off the brake (keep the go pedal floored) the car will launch like a bat out of hell! Keep in mind once launch mode is enabled, you only have about 5 secs to use it before it cancels outA few people have mentioned launch mode, I've never been able to get that to work, all I get it both pedals pressed warning. What's the trick?
Do tell more!If that 5% in Performance software update (not the upper end of 162mph update) come out for Model S and Model X P100D, could this allow us to get some better numbers? Just curious.
Yeah I'm all good on the Lud+ mode, but is there also the Max Battery Power mode to enable as well or is that automatically enabled after you do the star wars animation for L+ ?You have to be in Max Battery Power mode, not necessarily with the batteries heated up all the way, but in the mode.
Automatically enabled; basically max battery power is Ludicrous Plus once the batteries fully heat to the 50C, but up until then you can use Launch ModeYeah I'm all good on the Lud+ mode, but is there also the Max Battery Power mode to enable as well or is that automatically enabled after you do the star wars animation for L+ ?
