How are you finding the new control arm bushes?
I haven't had a chance to drive on them yet, will report back when I do!
Mounted up a set of Hankook R-S4's - going to give these a shot and see how they compare.
Also installed a set of Carbotech RP2's from Martian Wheels on the rear axle of a different 3, hmm, more info to come there!
View attachment 542168 View attachment 542169View attachment 542171
Thoughts on the 275 tire width? I am running a 18x9.5 , ET34 wheel and my shop doesnt think I can fit a 275 wide tire up front without rubbing
Interested to hear what you think about the RS4s. What were you running previously?I haven't had a chance to drive on them yet, will report back when I do!
I have 275x35 on 19x9.5 et40 - it fits, but wheel sensor needs to be pulled back. So 5mm spacer.Thoughts on the 275 tire width? I am running a 18x9.5 , ET34 wheel and my shop doesnt think I can fit a 275 wide tire up front without rubbing
That's really close. Are you driving with that camber all the time?
Your pics are awesome!
I know it's been said before but #noshimparty
Please report back your findings
I'm much more concerned about uneven tire wear. I don't drive every street turn with 1G lateral acceleration to compensate for that high camber. And I use highways. In my case I have 100Y 275 tires and that makes potential problem even worse.Haven't noticed any real impact on range, so why not!
I know, right, but I lost bunch of R888 before due to the camber, so I'm cautious and interested in your actual experience.I wouldn't worry too much about the wear unless your toe is out of wack. Toe will kill tires much quicker than a few degrees of camber will.
How much camber?So far the only wear I keep getting is outer edge wear, but I also don't daily my car.
How much camber?
