Well my goal for the weekend was to hit 3:00 on VIR Grand, and I was able to obtain that! I set my PB with only 9 laps of VIR Grand under my belt. Being such a long track (4.1 miles), you have about 2 chances to set a PB from 100% SOC (you use 10% per lap). I started with 90% SOC, so after my warm-up lap I knew I had one chance to do it, and I managed to get it done. The next lap I hit traffic anyway, so it worked out.
The car performed very well. The only issue I had was brake fade into turn one immediately following my PB. I actually got the brakes over temperature warning and SMT showed temps over 1200f. Fortunately, I am working with Essex for a permanent solve for that issue. It seems the rotors are just too thin to handle the mass of the car, which isn't terribly surprising. That being said, it only became an issue when I started pushing 10/10ths.
Here's a video. I mounted an external microphone under the frunk. I didn't consider how much noise the tires would be making, but the motor sounds pretty cool. May need to relocate it to the rear drive unit area. Also overlaid the data from SMT which is pretty sweet!
