I'm not trying to argue with you. I'm just sharing my experiences that I've had with Tesla as they steal power from my car.
As I said, you can be as placid as a Hindu cow and just accept whatever Tesla gives you. I'm not saying that you shouldn't.
hmmm. ad hominem. Can we not have a clean debate?
How did I misrepresent your point? You said launch mode introduces inconsistency. I merely pointed out that Tesla removed your ability to have consistent results with 1600 amps. 1600 amps is no less consistent than 1500 amps. So, the car does not perform as well as it used to. If you want more consistency, you should use sport mode. They adjust max current for you to keep the max power at a constant 390 kw. Your ets won't be close to 11.05 secs, but you don't care.
You are correct, I do not care. What I do with my car is not dependent on 1600A. even so, 1600A has yet to be shown to pull down that magical 10.9 pass that so many people seem to care about. Since I never had the necessary power to begin with why should I start crying about it now? I didn't buy this car to be a dyno queen. I bought this car because I like the concept and the way it drives. Since none of that has changed, i don't see cause.
Sport is no more consistent than Ludicrous. 1600A draw, however, I have experienced the car slow down as SoC drops. When I get back from travel, I can post them up if you like. In the interim, I suggest you experience this for yourself. There are several tracks in Florida.
Well, we wouldn't have to drive around with hot batteries if they hadn't coupled the extra 100 amps with the battery temperature optimization in an attempt to make it less available.
I have never seen any log showing 1600A available without Max battery, ever. Do you have something to share?
If something Tesla does lowers the value of your car, whether you use that feature or not, you've been damaged. Who knows? Maybe shared experiences you have will someday convince you that you would like to have access to those 1600 amps. Or the person who buys your car from you might like to have 1600 amps.
Are you saying I do not have access to 1600A? I can prove otherwise through datalogging.
Also, your opinion on value doesn't match the market. A vehicle that destroys the battery over time due to an unaddressed design flaw will be inherently less valuable than a vehicle that doesn't. If you are trying to use the value angle then you would want this change.
Like it or not, a design flaw was uncovered with the P90DL. Tesla addressed it in a way no one liked. They later readdressed it in a way that is much, much more palatable. If you are so slighted that you feel the need to constantly rage on the internet, perhaps you should sue tesla and force them to buy back your car. Or, perhaps sell it outright.
If you need another cat, let me know.
