Parking/Vision Assist on 2023.12.300.1
Yeah!
Reactions: travie
I think we all know the answer to who well this will work. There is only so much SW can do to make up for the lack of hardware.
Glad it is finally rolling out. I wouldn't trust it though unless I verified what it said in a lot of different situations. The 3 I drove with this wasn't impressive at all. It was downright wrong at times, by a lot.
Reactions: carnutdallas
Just got it! Glad to finally have something close to USS functionality… It is definitely not as good as USS, but seems to be accurate enough I can more confidently pull into a tight spot and my garage.
Interesting that the “Park Assist Unavailable” message is there, as it seems to give the lines but no numbers. Have restarted and everything, seems to be a “calibration period” like Autopilot.
I had the same message after update.
You need to do the following:
- turn all options from Autopilot screen to off
- restart car by holding both wheel buttons down for 3 secs
- then go back and re-enable all autopilot options
This solved my issue
I second this fix. Voila. I hope it will calibrate it correctly soon. First night parking in my garage and it shows stop with 18 inch left from the wall.
Reactions: CDrury
