Hi everyone,
First post here. I purchased and have been enjoying my 2.5 Roadster Sport since May of this year (#1314). Occasionally reading through the many posts here, but just now joined to make a contribution.
I have some experience that relates to this thread. My observation is that the PEM cooling method could definitely use some improving, and I suspect there are additional updates on the way, though I have had no indication of that when I asked Tesla Service people.
Some of the earlier comments in this thread echo my own experiences, and when my car was recently in for service, I asked them to address as much as possible the high PEM temperatures, and reduced power behavior I experienced almost daily on my afternoon drive home from work. I live in South Carolina, and August-September we get high humidity with temps 90 and above. To me this is to be expected, and the car should be able to deal with such an environment without so much as a peep from the energy system. And it does, with the exception of PEM cooling. So the Tesla shop performed a service procedure on the PEM and found substantial cleaning was needed, for road dirt and debris. My (2) blower fans were still in working order. So, I got the car back, and now it is my turn to take some steps to improve the situation.
I made the same observation that others have posted, regarding the (unfortunate) delivery of moisture and "airborn material" to the PEM (and Tesla drive motor) by the cooling blowers. The two actions taken were to install a filter for the blower airflow, and to improve the wheel well enclosure under the rear body panels, adding a partition to separate the cloud of high velocity road debris, moisture, etc, from the airspace around the cooling blower fans.
The work was done a couple of weeks ago, and I wish to share the method and results.
So, now I have "27 color glossy pictures with circles and arrows and a paragraph on the back of each one to be used as evidence" -of the repair.
(with thanks to Arlo Guthrie
http://en.wikipedia.org/wiki/Arlo_Guthrie and Officer Obie
http://en.wikipedia.org/wiki/William_Obanhein)
Err, A little US culture/humor from the previous century there, but I do have detailed pictures and explanation of how this was done on my 2.5 Roadster. It was not a difficult task, and materials were easy to obtain and work with.
The goal of this work is just to improve the environment the blower fans operate in, and eliminate most all debris delivery to the PEM and motor by the cooling blowers. Hopefully it will also help prevent premature failure of the blowers. A secondary result may be improved PEM cooling, at least to the extent that the dirt was the cause of higher PEM temperatures.
Like I said, the work is done, but now the season has changed to cooler temps and it will be another 8-10 months before the thermal performance can be observed.
Images from before and after modification:
