Do you know this first hand, SByer?
Yes, the clutch is engaged in first or second at a "standstill" - which isn't standstill, really, since there's programmed "creep" in the car. I didn't find the creep too objectionable, though I'd rather have the option.
I doubt that the motor is allowed to rev in neutral - there's really no point - so I don't see any way to pop the clutch. I suspect that the only time power is allowed to flow is when a gear is engaged. I neglected to test that specifically, though (and since you wouldn't really hear much, again, what's the point?)
Given what I felt when switching gears (this was with a version of the second(?) transmission), I'm pretty darned sure that switching gears while moving was the only time the gears were disengaged/reengaged. It's not something I have a direct answer on, and I certainly wasn't going to try and abuse the transmission.
Hey, the thing is so fun to drive, there there are all sorts of interesting questions you forget to ask until a while afterwards, when your senses have returned.
