Not sure I agree with you and
@WilliamG on this. For example, when you are in track mode and toggle to rear bias, the front motor will make some amount less HP/Torque (check). I think your other assumption is that the rear motors infinitely make up for the HP/Torque the front gives up. Perhaps, but I'm not convinced there is capacity there, or if this toggle changes anything with the rear DU controllers. Take the extreme case that one poster proposed - front DU is turned off - do you really think the rear DU will increase output by over 300HP?!
Time will tell. We will need 0-60 times and more before we understand what this, "work-around" fix for an obvious design flaw actually does (or doesn't). ARNR, anyone?
