JRP3
Hyperactive Member
You might try contacting some of the people on DIYelectriccar.com who might be able to point to to a higher voltage inverter, or build one for you.
Seems nothing I have on hand is happy trying to charge the pack as a whole.
Working on finding a temporary grid charging solution...
I thought the pack was setup S96P74, which fully charged to 400V would be 4.167V per cell.
Been doing a bit more research and it seems that I still can not find any commercial off-grid inverter that will accept a high input voltage in the range of the Tesla pack.
The range of voltages I've seen while supercharging is as low as 340V (4 RM) to as high as 403V (265 RM). So, I would need an inverter that could handle that input if I wanted to leave the pack intact.
Unfortunately the lack of a commercially available off-the-shelf solution is probably going to lead me to dismantling the pack into its 16 modules and rewiring them for a lower voltage. This would have the added benefit of easy transport later, also, since each module should be under 100 lbs...
Broken down into modules gives me the following possible configurations:
Configurations in red are not utilizing one or two modules, so, unlikely candidates.
Modules
in seriesModules per group
in parallelVoltage Charged Voltage Discharged 16 1 403 340 8 2 201.5 170 4 4 100.75 85 2 8 50.375 42.5 1 16 25.1875 21.25
3 5 75.5625 63.75 5 3 125.9375 106.25 7 2 176.3125 148.75
Given this info, an off grid inverter rated for 48VDC input should probably be able to function in the 2 modules in series 8 in parallel configuration. Most I've found seem to accept a voltage range from about 40VDC to 60VDC, which this configuration would fall under easily.
I'm definitely not going to break them down into sub-module portions for sure. Honestly, I'm still hoping to find a high voltage solution, however I'd prefer not to have to build an inverter from scratch...
Many grid-tied inverters would accept the full high input voltage. However, I'm not 100% sure how this could be made useful.
Lets say I make a micro-grid that has nothing connected to the utility. Lets say I have and use something like a 5000W off-grid pure sine-wave split-phase inverter running continuously to get a phase, voltage, and frequency for the base of this micro grid. What happens if I put something like a 20,000 watt grid-tied inverter feeding my micro-grid powered by the HV battery pack (and solar charging). What does the grid-tie inverter do when there is less than 20,000 watts demanded on the A/C side? Does it adjust it's output accordingly? I'm thinking not, since it wasn't designed for this. My guess is it would bump the A/C line voltage up (trying to force it's power on to the underutilized micro grid) until it reached a cutoff, then just shutdown completely. Just a guess though.
Anyone have any suggestions on this? I'd prefer to keep the pack as intact as possible, honestly.
I wonder if you could get your hands on one of the Tesla/SolarCity backup inverters... They are supplied/built by Tesla, normally uses a 10KW pack, probably could use a larger one... Charges from solar as well. Wonder if they are just using a Xantrex system plus maybe some custom BMS.
They likely don't run at high voltage input...
Your probably right. If they used just 2 sets of 73 cell modules, they'd have 5.31KW * 2 (about the 10KW system mentioned), at about 48VDC, so could just be an Outback Radian type of system (those are 4KW and 8KW, maybe they made their own similar product). These can be ganged together (up to 10), is this what you mentioned above? 80KW at 48V max?
Outback Power Inc. - Radian Series GS8048A / GS4048A
What I was attempting to rationalize was how each module would have 6 groups of 74 cells when there were only 4 visible contact plates on the top. I'm surmising that half the cells in each module are "inverted" to make that happen...
Actually the system wouldn't be in NJ, it would be in NC.
But the drive for off grid is that to me, the concept of net metering is more politics than anything. At any moment something with that arrangement could change and I could end up with a bill for grid use instead of using the grid as a battery, per se. Best to just use my own battery and let the grid be the grid.
I'd still have some power from the grid, but in the end I'd want it for just backup.
