Please field report any Canadian Supercharger problems to Tesla
Discussion in 'Canada Supercharger locations' started by Jaff, Jan 22, 2016.
Tags:
  1. Jaff
    Jaff Active Member
    Grimsby, Canada
    Hi All,
    My wife was using the Port Hope Super Charger last night...she encountered a red ring at the first stall she tried to hook up to...her subsequent attempt at a different stall worked fine.
    It occurred to me that we should email a field report of any Super Charge "hook up fails" to Tesla...I contacted the Yorkdale Store...they agreed, and asked us to email in any field reports of "session failures" to them
    at [email protected]
  2. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    I had the "red ring" happen when I connected to the B charger and the A charger was occupied.
  3. Footbag
    Footbag Member
    Edmonton, Canada
    At red deer I had the cable get stuck in my car. I spent about 5 minutes trying to free it (pushing it in before pressing button, not pulling too early, etc). I finally called Tesla (chose the option about supercharger issues), and after another 5 or so minutes on hold, got connected with someone. She didn't seem to fathom how the cable could be stuck in the car (not being released). Once she finally understood, she basically said "oh... that's not good then" <yep, that's why i'm calling for help!>. By this point a good 15 minutes had passed, all the while I was fiddling with the cable, and it finally freed itself. Shortly afterward I had a charge port failure, so this may have been an early warning of impending failure. I just found her response rather amusing (especially as I got free at about the same time... I may not have been laughing if I remained stuck).
  4. Jaff
    Jaff Active Member
    Grimsby, Canada
    You were absolutely right to phone them as you had an emergency situation.
    The purpose of emailing TM when a stall is out of order is to let TM know ASAP so they can trouble shoot and fix the stall asap. ..we have so few Super Chargers in Canada, we want and need all of the stalls to be operational as much as possible.
  5. Hugh Mannity
    Hugh Mannity Mediocre Member
    Calgary, AB
    Do we need to inform them? You'd think a red ring would auto alert the tesla collective?
  6. Jaff
    Jaff Active Member
    Grimsby, Canada
    Just using the "squeaky wheel" gambit Hugh...we haven't had that many report of stall failures in Canada...might as well watch some case study examples to see how quickly Tesla responds to these issues...at least for a little while.
  7. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Is 2B at Lawrence still down? It was down my last two times there, which were 6 months apart.
  8. green1
    green1 Active Member
    Calgary, Alberta, Canada
    Do we know if they actually action things sent to that email? I feel that a supercharger stall not working is always worth a phone call. Last time I called there was zero hold time, and the whole conversation took less than a minute.
  9. InternetDude
    InternetDude Member
    Yes
    Can I report the problem that they don't plan on putting any Superchargers in my province? ;)
  10. Jaff
    Jaff Active Member
    Grimsby, Canada
    I was told by Tesla that we should send an email to report any stall that was not working...I was told this when I phoned in to the Yorkdale store to report a stall that wasn't operational at the Port Hope station.
  11. green1
    When have the stores ever known what goes on in the rest of the company? I'd phone corporate instead, there's specifically a menu option for supercharger issues, and is harder to ignore.
  12. Jaff
    Jaff Active Member
    Grimsby, Canada
    Have to been to the store at Yorkdale lately? The staff there are now more experienced and much better at dispensing advice than they were in the early days. Perhaps you should be less insulting to them. :rolleyes:
    Regardless, if we encounter a stall malfunction at a Super Charger, please either email or phone Tesla to advise them of the issue.
  13. mknox
    mknox Well-Known Member
    Toronto, ON
    Hmmm... I had thought that these things were connected and would report back to the "mothership". I found the second stall from the left at Comber gave me a red ring just before Christmas and then again about a week later. The other stall I moved to worked fine. I guess I should have called it in...
  14. green1
    They do, but with the information at our disposal when at a Supercharger we don't know what is wrong, so we don't know if it will call it in.
    Imagine a situation where the supercharger doesn't detect that a car is present, it won't charge the car, but it also doesn't know it has a problem it needs to report as it thinks it's just hanging out waiting for a car to arrive, not knowing there's already one plugged in trying to charge.
    Also if it's somehow misinterpreting charging data from the car, Car requests 100kw, it delivers 10, you're frustrated because it's so slow, the supercharger though thinks the car must be either cold or full so it thinks it's doing everything right.
    The Superchargers will likely report when they know there's a fault, but there are definitely situations where they might not work, but also not know that they have a problem. That's where us calling in helps.
  15. mknox
    Toronto, ON
    Tesla should post an 800-number on the Superchargers for owners to call in if they have issues. I wouldn't have known who to call when I was at Comber other than the number I've saved for roadside assistance (and wouldn't have thought that was an appropriate number to use).
  16. green1
    Many (though not all) of the superchargers I've seen actually do have an 800 number written on them. However if you call the normal Tesla roadside assistance line there is a specific menu option for supercharger issues, so yes, it appears it is the appropriate number to call.
  17. Spurkey
    Spurkey P04251
    Edmonton, Alberta
    They do - at least the ones in Red Deer & Canmore do. The number is on a little sticker on the interior red portion, just below where the connector clips into the unit.
  18. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I was just at Montreal, and they did have a number posted on it. It's below where the plug rests when stowed.
  19. green1
    Most places do have the number, however the one time I wanted to report an issue was at the hope supercharger, and none of the pedestals there had the number. I called the number on the roadside assistance card and chose the supercharger option.
  20. Judge Advocate
    Mississauga, On, Can
