I echo
@TiggerTime and the question about the 20-amp circuit. That is a huge and expensive load center cabinet (“breaker box”) and switch for a 20-amp circuit...much, much smaller/cheaper options exist. I can’t imagine a more costly way to get a relatively paltry 16 amps to the vehicle. So, some questions:
1- is the installed load center supply wires and circuit capable of more than 20 amps?
2- is the wire size to the ChargePoint device capable of more than 20 amps?
3- are there local code restrictions that mandated the use of this equipment on such a low-amperage circuit?
I guess none of this matters now as you have what you have. If the setup is indeed capable of higher amperages safely and within code, you may with to upgrade to at least 40 amps so you can to get 32 amps sent to the vehicle, if the ChargePoint device supports it. You don’t mention which vehicle you’re charging, or I missed that. If a Model 3 LR you could go up to 48 amps with the Tesla wall unit and appropriate (60 amp) circuitry, and other versions max out at 32.
I have no thoughts about the battery unit.
