We are trying to understand how wide-spread this issue is, and to see if Telsa resolved the issue "in production" cars after a certain VIN range. Please provide as much color as you can, by commenting and voting!
Had this, it was the bracket that holds up the passenger rear seat. Wrapped it in electrical tape and the rattle went away. Have done this on a few cars.
Vibration felt in accelerator pedal; passenger’s also feel it on the floor and through the console.
Occurs: between 38 – 58+ mph
Conditions: Constant speed (e.g., holding 43-47 mph +/-), or under very slight acceleration in this range, especially after transition from regen (green bar) to slight acceleration (bit of gray bar)
Frequency: Occurs more than 50% of the time; varies in intensity from drive to drive
Started: Developed around the 2000 mile odo mark
“Feels” more of an electrical issue (DU, inverter, controller of some sort) than mechanical, but Tesla SC “supposedly” replaced half shafts and did a 4-wheel alignment (Did not fix the problem)…
Not tires as condition existed with delivered summer tires and SC installed all season Continentals
Not alignment as car tracks fine, although yoke is not centered; now skewed slightly right (after SC visit).
Added mine in @jebinc. Details from our posts elsewhere.
So it is definitely there, really subtle in my opinion. And really inconsistent. I could replicate it two or three times in a row, then nothing for several acceleration. Try again, get it once, then nothing. Try it again, nothing. Slow down, rev up and its there.
For me, it is closer to 50 although that could just be the speedometer turning faster my eyes can catchup / looking up and down. No passenger to confirm the passenger side has it in the foot well.
Sure sounds like something is loose.
Would help explain problem coming & going.
Closer look at suspension parts and ball joints and steering system too. Wheel bearing ??
@Brando Half shafts replaces, wheels alighted, tires balanced. Not fixed. Many seem to be infected with this flu as well, unfortunately. Inherent refreshed MS design defect, probably.
