When you power off the car in an inclined driveway for example, does the "park" breaks stay on? Or would i have to set blocks behind the wheels?
Only if your Parking ain't broken.I thought the parking brake is automatically applied when the Park button is pressed.
A little slow and was wondering what "parking breaks" meant and had to click? Is that click bait?
P.S. parking breaks to me meant what is called "hand break" on other cars.
I should have more explicit. I installed the OBD2 add-on cable connecter at the back of the center console. You obviously have to have the power off. I was asking if the park breaks stays on when you power off. I did press the park button with foot on brake for 4 secs.
It stays, but I put blocks also just in case...
"Brakes"When you power off the car in an inclined driveway for example, does the "park" breaks stay on? Or would i have to set blocks behind the wheels?
There is a secondary parking brake that can be activated by holding down the park button after you shift to Park. You can try it yourself, the manual is technically wrong. Yes is automatically go in to Park but that's not really the "handbrake"
It is not a secondary brake. It just applies maximum pressure to the same parking brake mechanism when you normally put the car in PARK.
