Has anyone run into issues powering accessories, tire inflators or audio amplifiers with the new 12 volt lithium battery? I've read that it's actually 15.5 volts so that's much higher than what a lead acid peak voltage would be and might be out of range for what most amps and accessories were designed for. Plus the voltage would likely go higher when the car charges up the 12v battery which I assume would be often since it's a low capacity. Don't want to buy an amp or inverter for the car only to find out itll get fried.
Tha is in advance.
Tha is in advance.
