doubleohwhat
Did they provide you with any diagrams or spec sheets? I'm curious about the gateway that is supposedly installed with the AC powerwalls.
No. However, I believe I am one of the first the engineers contacted, and they might already know that I am pretty aware of the benefits and capabilities of such a system, so I am not sure that this would have been necessary in my case, and they may know that. I do not know what this means going forward for other customers. Obviously, the Tesla website has some decent amount of information on it, and it is a pretty basic thing, like Elon said in his introduction: "1. Solar. 2. Battery. 3. Use it at night. Yeah, that's it. It's pretty basic." On the web site, it explains some of the specs. I think the details will come out as people review the new installations, and if I had the total earmark for this available, I would have already signed and sent in the document for installation. As it is, I'm going to probably re-asses my particular goals, and reduce to that.Did they provide you with any diagrams or spec sheets? I'm curious about the gateway that is supposedly installed with the AC powerwalls.
Any idea what that asterisk is for? Is it just a "if TOU plan is available from your utility" or is there some kind of limitation not advertised?Reduce your electricity bill, if your utility offers a time-of-use rate plan*
Your primary breaker panel or the service breaker panel outside?$1,750 Possible Additional Charges: Main Panel Upgrade
It is not answered in the document. However, after the phone conversation I had just now, I inferred that this might only be available in cases where Time Of Use plans would make this attractive. While following general anecdotes about rate plans around the industry, I've noticed this will have almost no applicability in almost all areas, at this time, in California, due to the particular way our rate plans are structured and the overall payback of the system (including inefficiencies and lifetime use of the product). I believe, but I may be wrong, that load shifting is only useful in the following conditions:Two questions:
Good question. I plan to ask this later. I did not want to take away from his time from explaining to other potential customers, since I believe this week is a huge rollout week and they need all the time they can muster. I know my questions are the type that would elicit long responses that are mostly to educate those who don't know a lot, and I wouldn't want to put him in a spot of generalizing to someone who would rather have technical details, and like I said earlier, this is an evolving market. We all know where it's headed, but none of us knows the color or shape of the paths to get there, so it's kind of --- fun, but with a healthy dose of newness. However, I await the information as it unfolds over the next weeks.Your primary breaker panel or the service breaker panel outside?
Anyone have a estimated install cost?
The folks I'm working with a very responsive but they are from Tesla corporate I think.Going on three weeks since SolarCity came by for a PowerWall 2 site inspection and I haven't heard a peep back from them. Guess I'll have to reach out.
I think they're going to have to give in on this one in areas where SolarCity does not have a presence. I asked them the other day who would be doing my installation and was told they don't have anyone in my area yet.And, separate installer would void any warranty that comes with the battery. But Tesla would work with your installer if you decide to go down this path. I only asked because some here were wondering about this option.
May I ask which solar inverter you are (or will be) using? Tesla has told me their AC coupled powerwalls will somehow trick grid-tied inverters (that typically go down with the grid) into staying online during a grid outage to charge the batteries.
When I talked to Swell Energy he explained that their installation for the AC PowerWall will set up a critical loads panel inside the gateway/transfer switch and they would move the solar to that new panel. That way, when the grid is down, the solar can still charge the PowerWall. He said they like working with Enphase systems (which I have) but he didn't say why. Maybe they can talk to the Enphase gateway to know how much the solar is producing?May I ask which solar inverter you are (or will be) using? Tesla has told me their AC coupled powerwalls will somehow trick grid-tied inverters (that typically go down with the grid) into staying online during a grid outage to charge the batteries.
Ah, that makes sense. I guess the Tesla gateway would have to prevent the batteries from being 100% depleted overnight. Otherwise the Enphase inverters and gateway would be deactivated (due to them thinking the grid is down) the next morning.When I talked to Swell Energy he explained that their installation for the AC PowerWall will set up a critical loads panel inside the gateway/transfer switch and they would move the solar to that new panel. That way, when the grid is down, the solar can still charge the PowerWall.
Sure, that's also a possibility, but there are cable length limitations that would prevent it from working in all situations.Or maybe they can hook the new generation of Wall Chargers up to the Powerwall system via the multi-WC interface to control how much power can be used at any given time.
Easier than what, specifically?Wouldn’t it be easier just to add more solar panels?
To solve what problem?
First, you should size your solar for you total usage, including EV charging, corrected for TOU credits and net metering rules like NEM 2.0 Non-Bypassable Charges. What I'm trying to say here is that it is more cost effective to aim for close to zero net dollars per year than net zero kWh per year.
Second, PowerWall cannot offset or reduce your usage, it can only shift it to a different time period, while losing a little energy in the process. PowerWall is useful to either reduce the billable charges from the utility, or to keep running through utility power outages, or both.
