Powerwall Arbitrage DEAD: San Diego's SDGE
markb1
3,031
638
San Diego, CA
Regarding the discussion above of non-bypassable charges, I’m looking at a friend’s SDG&E bill, and his net metering summary shows NBCs of just 52 cents, and that’s 5 months into his first true up period. He got a new meter at the same time of the solar installation, and it shows about 1700 kWh consumed and 3800 kWh pushed back into the grid. How could the NBCs only be 52 cents?
markb1
3,031
638
San Diego, CA
Is he NEM 1.0? If so, and he's produced more than he's consumed over the billing period, the NBCs should be zero, to my understanding.
Cheers, Wayne
I think I figured it out. It's that "non-bypassable charges" really means "non-bypassable charges in addition to minimum charges". The "minimum charge adjustment" on this bill is $49.31, which mean the actual non-bypassable charges amounted to $49.31+$0.52. It's just the weird and confusing way SDG&E does accounting on their billing statements.
Since he's generating a lot more than he uses, he can accumulate up to about $120 a year in non-bypassable charges on his account with no affect, because everyone has to pay a minimum of that much, anyway. (There are actually a couple things than get subtracted after the minimum bill, it seems, like California Climate Credit and Reduce Your Use awards.) Good to know when trying to estimate the affects of NEM 2.0 on your bill!
miimura
5,989
5,567
Los Altos, CA
I have tried to figure out PG&E's NBCs and NBC Adjustments and haven't come up with anything that actually made sense. I'm on NEM 1.0, so it's mostly academic to me unless I want to add more than 1kW more solar.
markb1
3,031
638
San Diego, CA
What's really annoying is that SDG&E's bills don't have enough data on them to reproduce the calculations. They don't even put the monthly meter readings if you're a net metering customer!
miimura
5,989
5,567
Los Altos, CA
The PG&E bills likely have the data required, but I tried to calculate based on the tariff and came up with figures much larger than what people were actually being charged. The Tariff also doesn't talk about the Adjustment portion. I would go into more detail here, but it probably belongs in the existing PG&E NEM 2.0 thread.
Sep 24, 2015
810
683
San Diego (Oceanside)
I have two choices: more solar or a PW2
Option 1 (proceed with PW2)
Made deposit on PW2 in April with SGIP. Cost pre rebate $21,839, SGIP2 = $9400, ITC=$6551, net cost $5,888.
In SDG&E territory with EVTOU2 rate. Solar produces 10K kWh, annual use is 19.5K kWh.
Two EVs: Model S and Leaf, receive $400 EV credit on bill. As credited 50 cents/kWh for on peak in summer (12-6 pm), value of peak excess production makes for $100 summer utility bill (6 months). In winter, use 6,000 kWh, with net bill of $1,200 (less EV credit) total annual bill about $1,000. 1/2 of winter electric is for heating in north San Diego county.
Approx 1,000 kWh of summer production used during peak time (12-6 pm), if used PW2 to shift morning production to afternoon use, would save additional $300/year. Factoring convenience, would normally shift another 1,000 kWh from morning to afternoon (value at perhaps $200/year. (would allow not to run AC 10am to noon on hot days prior to peak rates). All in looks like 12-19 year payback.
Option 2,
Get more solar panels, cost for 14 more panels about 7K, net of ITC $4,900. Est production of additional panels 3,000 kWh/year. If 30% (970 kWh) at 50 cent per hour rate, lowers bill by $500 plus 70% (2300 kWh) at 20 cents/kWh $450 saving. Total $950/year which would zero out my annual bill (leaves the $10/month minimum charge). Payback about 5 years.
So unless I'm missing something, the financials seem to say just do more solar with NM 1.0 EVTOU2 rate.
What am I missing? As far as I know the EVTOU2 rate is here for the duration. I'm grandfathered in for 17 more years with Net metering 1.0.
I could see the value of having backup at perhaps $100/year as it doesn't happen often. There is the novelty factory too of having a power wall and perhaps that's worth $1000. Might end up doing both but at some point, one wonders can I reach my state of energy bliss.
Input appreciated.
Did you end up going with the PW2's? How many did you get?
Curious how everything went as I'm considering the option as well.
Xminus6
696
468
Bay Area, CA
This is news? Net Metering has always worked this way.
Agreed. Mine is this way as well In PG&E land. You’re always better off finding some productive way to use that excess energy rather than selling it back at wholesale rates. Run a pool pump longer or whatever else that is beneficial to you.
montreid
237
173
san diego,ca
SDGE land; NEM 1.0. PV 3.8kW Solaredge; EV x2 charging at night. EVTOU2 schedule
--My understanding: Grandfathered into Pk hours 12n-6p for 5 years until 2023.
Added PW2 x1. two weeks ago and learning some interesting things.
Setup: While on grid - and in self-consumption mode --- works like you'd expect
Priority house usage draw is solar>battery>grid.
Priority CHARGE is house >battery>grid.
-there is NO way to discharge the battery to the grid under current programming. ie no full arbitrage. If you want to do that, don't use PW. Get traditional batteries to do it.
-the closest you're going to get is time shifting energy for self consumption. This is key for NEM 2.0 and future folk where peak TOU is 6-9pm or any future non solar days.
-the discharge support is 5kw. That's good for most anything except AC and EV charging.
The total cost of tesla install was $7600 - SGIP ~3500 - ITN ~2300 = ~2000 for backup +time shifting capabilities. ROI is probably 5-7 years at best, so not cost effective compared to direct solar panels (but we've tapped out of roof space).
cwied
867
616
San Mateo, CA
It might be worth factoring in demand-reduction into your equation. As far as I can tell, you can get quite a significant amount of money from OhmConnect if you have an EV and are in the San Diego area (although all areas down there might not be equal). There is an OhmConnect user who's getting $2000/year because he can change his usage by 7-8 kWh during his OhmHours by charging his EV on other days. With the Powerwalls, you can make sure your usage is 0 during the hour.
It appears like the demand reduction payments are somewhat less up here in the SF Bay Area, but I did get over $8 for each of the last two events (with about a 1.5 kWh reduction). So far this year, I've been getting 5-6 of them per month. One drawback is the income is taxable and will be reported on a 1099 if you exceed $600/year.
Note that demand-reduction is mutually exclusive with self-consumption. You have to have a demand from the grid to reduce. You can manage this by setting your schedule so you demand-reduce for part of your peak (usually after the sun goes down to avoid penalties from cloudy days) and self-consume the rest.
Reactions: SoundDaTrumpet
Frankman60
415
86
San Diego, CA
This is the first time I have heard of the OhmConnect program. I read through the OhmConnect website but would appreciate hearing others experience with OhmConnect and Solar, and Powerwall users with OhmConnect. It seems like you may not get much advance notice for when an OhmHours event occurs and at that time the PWs would need to be in Self-Generation mode and providing all of the energy to the home. How does one effectively manage this to actually money?
NuShrike
459
193
SoCal
I've been using it for a few weeks. They are advertising hard on Facebook from my POV. Overall, it's a much better demand-response system than SCE's, and doesn't seem to be a scam.
I don't give them my login password for SCE (at the end after signups), but I signed them into SCE's the third-party data access system. I've already moved my high-usage appliances and equipment to TP-Link smart-plugs so OhmConnect can automate turning things off (including Ecobee 4).
To control for event occurrences, you set preferred hour-bands to outside your PV hours "Times You'd Like to Receive #OhmHours ". Mine is set 12AM-7AM, and 6PM-12AM. This removes it from using PV hours that would fluctuate depending on weather. Weather is low occurrence in SoCal, so personal preference on settings.
Whenever Tesla's Gigafactory actually puts-up and actually starts shipping PWs to installers, such as Infinity Solar so I can get mine installed, I plan to use the PWs to cover more bands.
If one does EV charging, maybe the charging system has an API to automate synchronization with OhmHours.
cwied
867
616
San Mateo, CA
The way I do it is to keep my Powerwall at 100% backup reserve except during OhmHours. The other trick with solar is to make sure not to get OhmHours during net-negative times as a cloudy day can ruin your OhmConnect streak. Streaks are key to earning the best return for OhmHours. Whenever an OhmHourhits, I set my Powerwall reserve to 50% (using IFTTT and a node server script I wrote) and that gets me the reduction I need. I don't have an EV, so I don't need to coordinate the charging.
My TOU peak time is 12pm-7pm during the summer, so I intend to run self-consumption until 7pm and then be available for OhmHoursafter that. That means on most days the Powerwalls will be off after 7pm. If I get into SGIP, I may need to add some consumption hours overnight to qualify.
The Powerwall is a great match to OhmConnect, because you don't have to worry about switching any of the backed-up loads off during an OhmHour. Self-consumption takes care of it automatically. With the IFTTT automation, I essentially don't have to do anything at all to get the benefit.
One thing about demand reduction that bothers me a little bit is that there is a perverse incentive to use more energy on non-event days. Given the payout levels, it seems like you profit off of extra usage that boosts your baseline for the OhmHour calculation (it uses the average of the same hour on the 10 previous non-event weekdays or 4 previous non-event weekend days).
Frankman60
415
86
San Diego, CA
Thanks for your comments cwied and NuShrike. I have solar and will be getting 2 PWs installed in a new months. It seems that if I want to sign up with OhmConnect I should do it maybe two weeks before the PWs are commissioned because they measure a baseline using 10 days of history? Once the PWs are working, they should be providing 100 percent of the home’s electricity usage between 4 PM and midnight. EVs begin charging at midnight when rates are lowest. In my area (SDG&E) peak period is 4 PM to 9 PM. If I am understanding this correctly, my baseline would be calculated using my pre PW usage. After the PWs are installed, there will be no grid draw during that time, although some energy will be sent to the grid during that 5 hour period. In my case would it be best to define the OhmHours as 4 to 9 PM (peak)?
NuShrike
459
193
SoCal
You may want to sign up earlier because clearing the "paperwork" through your utility may take a couple weeks. It did for me with SCE ...
You don't have to participate until you want -- opt-out whenever you want (though if you want to keep your "streaks" ...). However, even the little things, like turning off fridge or tv(s) during OhmHours is enough to participate.
With your solar, your more effective OhmHours would be 5-6 to 9pm due to solar. You can calculate how using peak-power without PW vs with gives you better arbitrage. Such as not using PWs between 8-9pm most of the time (would be covered by net metering anyways?), and then once a week during OhmHours, use the PW to zero 8-9pm usage for the points.
Just calculate it out to your own preferences and tolerances.
miimura
5,989
5,567
Los Altos, CA
Cheers, Wayne
NEM 1.0 does not have Non-Bypassable Charges. Only NEM 2.0 has those. That said, if you are on NEM-2 and you generate and export 50kWh per day during daylight hours and consume the same 50kWh during overnight hours, you still have to pay the NBCs for the 50kWh consumption. That is the whole point NBCs - you owe something for the consumption that cannot be offset by your generation.
cwied
867
616
San Mateo, CA
Just to emphasize: self-consumption and demand-reduction are mutually exclusive. For each hour of the day, you have to decide which you want to do. The baseline is always the last 10 non-event days, not the ones from before you start the program. If you self-consume on those days, your baseline will be 0 and you will not be able to reduce further.
In my case, my peak hours mean that I can't arbitrage effectively after 7pm anyway, since I'd be using shoulder electricity stored in the battery to satisfy shoulder load. You probably have to do a more complicated calculation to see which would pay more. Don't forget income taxes when calculating OhmConnect's payoff, though.
miimura
5,989
5,567
Los Altos, CA
Tesla needs to come up with a Demand Response program tailored to the Powerwall and run it through the California regulatory system. Then they could offer an aggregated Powerwall virtual demand response power plant with compensation to individual owners who opt-in to that program. OhmConnect is just not suited to the normal Powerwall user.
Jun 22, 2017
526
337
Bay Area, California
The OhmConnect doesn't go very well with solar. Because it is based on 10-day history, it's okay for me to opt-in in the spring/summer as the days grow longer, and when I actually have real controllable loads like A/C. Opting-out in the fall/winter destroys streaks so I only participate once a week (a setting), and schedule only the night hours. It's a game, and not a set and forget type of demand response. I have gone as far as charging my car before 7AM with hopes of catching an OhmHour... sounds wrong... creating demand when there is a better time to do it. OhmConnect has dropped their support for my EV and my JuiceNet enabled EV charger, so EV charging has to be stopped manually. Considering this is a Tesla forum ignore Juicenet (all their hardware is non Tesla connector), hopefully Tesla can introduce a demand response program for their chargers as well. Juicenet I estimate $50/yr. OhmConnect $80/yr. No Powerwall for the above.
