I thought it might be useful to share what I’m able to see using my Juicebox charger when it comes to preconditioning before departure. The screen shot below was taken after 17 min of preconditioning, while plugged into the charger obviously, and the battery was already at its charge setpoint. The MY was parked in a 50F garage.
When preconditioning first starts, you can see that it consumed my chargers entire 10kW of output power, but only for a couple of minutes, and then it starts ramping down to around 8 - 9kW. Then, after 15 minutes exactly or 2 kWh of energy spent, the motors stop generating heat and the power draw drops to around 800w, which is how much power it takes to continue running the heat pump alone to maintain cabin temps.
To compare, when you precondition without being plugged into the charger, it only preconditions the cabin, not the battery. In fact, it’s actually cooling the battery off since the heat pump is scavenging heat from it, assuming there is heat there to recover.
