It does say that, but I think the car it was on was the Renault not the Nissan.Did it say "AC propulsion" on that LCD panel?
Doesn't Nissan make their own EV drivetrain?
...the Model S’ battery can also be swapped out in just five minutes, making it compatible with Shai Agassi’s Better Place initiative...
Is it official? They didn't say much about it, but I saw this reported about the Model S:
2012 Tesla Model S revealed! (updated)
...The flat battery pack can be designed into the car to be easily and quickly removed and swapped for a fully charged pack when it is depleted.
Musk said this doesn't mean that it will be designed that way, or that Tesla is going to evangelize for a national battery swap standard, but it does mean that if everything came together and battery swapping instead of plug-in recharging became the thing to do, the Tesla S would be able to do it...
:biggrin:...and in the San Francisco Bay Area not only do you have the highest concentration of Priuses, but you also have the perfect Range Extender: It's called "The Other Car"
I keep reading stories suggesting that this was some sort of new, breakthrough idea....But Agassi realized he needed one more breakthrough: some way to rapidly charge a vehicle. No drivers, he knew, will tolerate a two-hour wait to recharge when they’re on a 500-mile haul. Then one day, he and an automotive engineer were chewing over an impractical method for quickly replenishing batteries. The engineer wondered aloud: Wouldn’t the fastest way to charge an electric car be to simply replace the battery?
It was, Agassi says, his “aha” moment. ...
The New York Times
Printer Friendly Format Sponsored By
April 19, 2009
The Green Issue
Batteries Not Included
By CLIVE THOMPSON
Shai Agassi stood in a warehouse on the outskirts of Tel Aviv one afternoon last month and watched his battery-swapping robot go to work. He was conducting a demonstration of the curious machine that is central to his two-year-old clean-energy company, which is called Better Place. Agassi’s grand plan is to kick-start the global adoption of electric cars by minimizing one of the biggest frustrations with the technology: the need for slow and frequent recharges. The robot is the key to his solution. Unlike most electric-car technologies, which generally require you to plug your car into a power source and recharge an onboard battery for hours, the Better Place robot is designed to reach under the chassis of an electric car, pluck its battery out and replace it with a new one, much the same way you’d put new batteries in a child’s toy.
Better Place spokeswoman Julie Mullins said plans for Bay Area stations are currently in the planning and permitting phase, with construction to begin around 2012, she said. Charge spots would be managed directly by the company, with no plans for local franchises.
Drivers would pay for access to the charge spots on a “subscription” based off of miles driven, comparing it to purchasing a cellular phone and an attached payment plan, Mullins said. Battery exchanges would be for trips farther than the estimated maximum range of 100 miles.
Better Place does not manufacture cars itself. The Renault-Nissan Alliance is developing an electric-powered five-door sedan that will be compatible with Better Place’s infrastructure, Mullins said. She added that other existing electric models such as the Chevrolet Volt and the Tesla Roadster would be able to use the charge spots...
I am going to call it now. Project Better Place is not going to be successful with this current business model. It doesn't make sense to build thousands of these battery swap facilities when they will so rarely be utilized.
