Use Case: Any BEV
Requirements: Home Charging w/ Garage
Materials: PVC pipe and elbows (1/2")
Tools: PVC Cutter & Glue
Difficulty Scale (1-10):
It's wonderful in the BEV world to be able to charge at home. If you do, you probably have an outlet or a Wall Connector. And that's great for charging 99% of the time. But what if you can't put the car in the garage for some reason? There are four choices....
OR
Buy a simple molded cable protector from Amazon or use my little 'gizmo'. Why not buy? The one we purchased was hard for my wife to fit the cable on (the diameter of the channel for the cable was almost the same as the cable itself) and it actually left indentations.
The 'gizmo' comprises of two lengths of PVC. It does not touch your cable at all. You can use straight or hooked like mine. Eight elbows, and 6 smaller pieces of PVC. All easily purchasable at your local DIY for around $10. Time to assemble is about 10 minutes if you have never made a diorama for your kids.
I liked the curved pieces of PVC as it's easy to tell someone how/where to place it. All you do is put the 'gizmo' over your cable straddling the point where your garage door would contact the cable....see pictures below.
Enjoy!
- Don't charge
- Remove the reason you can't charge in the garage
- Charge with garage door open
- Charge with the garage door closed and pinching your power cable
OR
Enjoy!
