I was at a supercharger earlier today and saw a bunch of 3s charging. Since they were all side by side, it was very easy to see that some of the “Dual Motor” badges were crooked. Make sure to check your badges if/when you get them installed!
The mobile tech had a special template to use to put the badge on. It's a foam template that they line up with the body work on the trunk that makes sure the badge is on straight.
The only way to screw that up is to not be able to line a foam block up against the curve in the bodywork.
