Ulmo
I must be really uninformed then.Our non PUP 2017 60D allows brake pedal closure of the drivers door. All doors open and close from the touchscreen.
In this case you are 100% incorrect. My model x without PUP. Drivers door DOES close when brake pedal is pressed.
At the end, I decided not to get PUP because I can't justify the cost. None of the options here make the car feel more "luxury" In fact, except "self presenting" door, you may not easily notice you have PUP installed
I tested it and the door does automatically close when you hit the "bake" (without PUP)
When you are inside, you can just "pull" the door lever and the door will either automatically open or close
You can also do this when OUTSIDE the car when the door is open. Instead of pushing the door closed you just quickly pull the INSIDE door handle and remove your arm and door automatically closes. Very nice feature and how I close the door when I leave the car most of the time.
My DS also showed me a method that I love: with the door open, "pinch" the inside of the door with one finger and another finger on the outside chrome door actuator. I usually use my thumb and index. It works brilliantly! Cheers.
Going to try this. Thanks.My DS also showed me a method that I love: with the door open, "pinch" the inside of the door with one finger and another finger on the outside chrome door actuator. I usually use my thumb and index. It works brilliantly! Cheers.
