I was going to post a couple pictures from my RV-8A (homebuilt airplane) project, but found How to crimp BNC connectors « Matt's RV-7 Project with a nice write-up on how to use these dies to properly crimp coax cable. Start with a tool to properly strip the coax (three different depths of cuts are required), use the die you referenced to crimp the pin on the center conductor, slide the ferrule and BNC/TNC/SMA/... connector onto the wire and crimp the ferrule using the hex shaped crimping die. Only takes a couple minutes to prepare and crimp one of these connectors with the right tools.
