The power to offset air resistance is proportional to the cube of the speed, but that is not a useful model for a car that has significant linear losses from tyre and road friction.
Air friction is 0.5*rho*CdA*v*v
Rolling friction is m*g*RR
Integrate these two frictions together, and remember that you are throwing away ~ half of the KE in regen your way.
This graph models a possible Model 3 with a Cd of 0.21 and area of 2.22 meter squared.
You can plug in speeds if you like, but it is obvious from eyeballing the graph that in this speed range the function is far from cubic. As one example, 90 kph is 1.5x the speed of 60 kph. If your cubic model was correct the power in kW at 90 kph would be 3.96*1.5*1.5*1.5 = 13.36 kW
