whttiger25
If you adjust the accelerator pedal such that the power line on the dashboard is 0, i.e. no orange or green line, essentially the electronics of the car not sending or accepting voltage/current to/from the motors. The rotors of the electric motors are essentially rotating without any electromagnetic resistance, so you are only losing energy from friction throughout the drivetrain. If you ease up on the accelerator to generate power and use regen braking, the electronics begin to accept current/voltage from the motors. What this does is generate mechanical resistance inside the motors as the rotors rotate past the fixed components of the motor, generating current and electromagnetic resistance. While you need a degree in physics to understand exactly how these motors work, basically as you rotate a coiled wire through a magnetic field, or a magnet past a coiled wire, voltage is created in the wire, and if that wire is connected to a complete circuit, current flows and resistance to the movement is also created. If the circuit is not complete, voltage is created but there is no current and thus no work/resistance. This is how mechanical work is converted to electric power. This current is sent to the battery. If that circuit is opened, or exposed to very high reistance, then only a small current is generated, and thus little or no resistance. The tesla increases resistance to infinity to disable e-braking (coast), minimizes resistance to maximize e-braking, and reverses the equation entirely and applies current and voltage to the motors to power the car.
The closest analogy to coasting in an ICE vehicle is to find this sweet spot of net zero power. The rotors of the electric motors already have their rotational kinetic energy and thus continue to spin without needing extra power to continue to do so (just like the earth continues to spin) and energy is only lost from friction. However, in the coasting scenario, an ICE vehicle still uses energy, as you need gasoline to idle, and a gasoline engine generates much more friction as you don't have a freely rotating rotor, but rather pistons that must be continually propelled to continue moving. If you remove gasoline from the system, the ICE freezes up immediately, while an electric motor at 0 V rotates like you have spun up a basketball on your finger, gradually spooling down from friction of air inside the motor and the axle only.
