Post your questions about Hansshow Android 4G 10.25-inch Tesla Model 3 Y Instrument Cluster Heads Up Display in here.
Seems like all the videos for install have been with the Intel LR Y. I have a Intel performance and was surprised I had to run through the firewall for power (it was in the instructions). All the videos make it seem like it's straight plug and play. Best thing to do is just search for videos on running through the firewall. There's a blue gasket in the frunk you can use to fish wires through.I just received mine today but don't know which is the best installation video available on Youtube. Any suggestions to try to have the easiest installation process possible?
I've watched many videos too and have come to the conclusion that Hansshow had made it very confusing by not clearly differentiating various versions of their products. On top of that, they apparently don't clearly describe installation differences between various models of car and different processors. In addition, it seems that most of their install instructions are unclear or ambiguous in some important steps. On top of that, I expect there have been modifications to some of their products that a given YouTube video may have covered. I figure when mine arrives I'll figure out what has to be done to install it.Seems like all the videos for install have been with the Intel LR Y. I have a Intel performance and was surprised I had to run through the firewall for power (it was in the instructions). All the videos make it seem like it's straight plug and play. Best thing to do is just search for videos on running through the firewall. There's a blue gasket in the frunk you can use to fish wires through.
The carplay connection from iphone to Hansshow is pretty reliable. However, the issue I have is the bluetooth from the unit to Tesla always drops and sometimes won't connect. I would have to unpair and repair.How reliable is it when automatically connecting to carplay when getting into the car?
Installed today. Data plug in my model Y made in Texas is located in the right A pillar as an Open plus (nothing was connected to it).
To pass the power cables to the 12 V battery did it through the rubber plus in the photo bellow (quite easyJet actually). View attachment 881490 View attachment 881491 View attachment 881490 View attachment 881491 View attachment 881492
My unit arrived yesterday. I have mounted it to the dash panel and today I will install everything in the car and make all the connections. Did you run the ground wire into the frunk or was there a grounding point in the lower A pillar area near the data plug? (I have Ryzen and li-ion battery). As expected, the install instructions are terrible, and there was no operating manual included in the box. Taking the best parts of numerous YouTube videos seems to work best for me. I expect the biggest challenge to be setting it up and doing all the correct pairing to make things operate reasonably seamlessly (for Apple carplay in my case).My problem now is to configure the unit for Android Auto. Can't make the music/audio to play. And the instructions from Hansshow are not updated and don't work for the unit received.
After a few more hours of YT videos and time in the car going through the settings, I finally got everything paired. I thought it was my phone that wasn't paired, because the BT that you are told to use for pairing it only gets used temporarily until I think the unit establishes another type of connection with the phone and the initial BT then disconnects. Then I found that the car system wasn't paired, which I thought I had done successfully yesterday. Once paired, the carplay audio played through the car speakers.
BTW, the two things I'd like to see added to the firmware are: 1. a way to adjust the display brightness independent of the Tesla screen. The earlier 9" version provided this adjustable brightness feature. 2. instead of showing if the car is using or adding power, show the specific power consumption - ideally instant as well as average for current trip. Even better, also show the car's lifetime average power use (in wh/mi).
Reasons:
1. I find the display a bit too bright for my taste (even in permanent night mode) and to adjust it down enough I have to take the Tesla screen to minimum brightness level, which is a little too low for that display.
2. The gauge showing power consumption/generation may be briefly interesting, but it is really of no value. Consumption rate info would be more valuable by allowing you to see if your power use is higher than normal for you.
I have a roll of Vvivid light smoke headlight tint film that I never used. I tried a temporary piece of it on my Hansshow screen and it does cut the brightness by a suitable amount I think, so I'll go ahead and install a correctly sized piece of film. BTW, at the bottom of page 4 of the Hansshow "Installation manual" that I received in my package last week, it says "The linkage and brightness between the home screen and the steering wheel screen automatically follow the home screen". That is why there is no brightness control setting on the Hansshow setup menu now.I agree, the display is way too bright at night it's distracting. I couldn't find a way to adjust it either, which is kinda lame.
I don't even use that screen since it's not of much use. I like have Maps up and then having the cameras on screen. In an ideal world it would be amazing to have all the camera views in front of me.
On my 9” linux hansshow, if I drag finger from top left of screen to bottom left of screen (straight down) I think it lowered brightness Or perhaps it was righ side. I do not believe this functionality was mentioned in my manual. Worth a try.I have a roll of Vvivid light smoke headlight tint film that I never used. I tried a temporary piece of it on my Hansshow screen and it does cut the brightness by a suitable amount I think, so I'll go ahead and install a correctly sized piece of film. BTW, at the bottom of page 4 of the Hansshow "Installation manual" that I received in my package last week, it says "The linkage and brightness between the home screen and the steering wheel screen automatically follow the home screen". That is why there is no brightness control setting on the Hansshow setup menu now.
