New 2017 coming soon. I'd like to use my Valentine RD. A visor mount is fine with me. Is there a fuse block in the driver area? Or a recommended 12-volt tap?
I believe you can find 12 V switched power in the area above and behind the rearview mirror. Using a Posi Tap or similar device will avoid cutting a wire. A search on the forum will verify the color and location of the wires..
Search the forum. Valentine is not going to work or will have limited range because of windshield comstruction. I do not think the situation has changed. If you discover otherwise, please post, as my Valentine has been in a drawer since I originally got my P85 and I did not try it when I upgraded to my P100d.
There was a similar recent thread with several people posting that the dampening effects of the windshield were improved with the refresh. I tried it preliminarily recently and my V1 worked where I placed it to the left of the rearview mirror. It seemed range was less. I have not tried it at alternative locations on the windshield.
The "open" spot is to the RIGHT of the rear view mirror, not the left to my knowledge.
I know you have a V1, so it won't help you, but I have an Escort Passport Max mount on Thingiverse that I designed to mount that detector in a Tesla so it fits in that exact spot. Works for both Pre and Post AP cars. You can probably adapt it for the V1.
