A GTR doesnt go 30-50 in 3.8 seconds, unless you started out in top gear, whcih no one will ever do.
In automatic mode, the transmission just can't wait to get you into 6th gear. Under light acceleration, you'll be in 6th by like 30 mph
Except they will. Pretty often.
2009 Nissan GT-R Long-Term Road Test - Comfort
So yes... yes you will be in top gear at 30.
For example let's say you're pulling away from a light about to turn into an on-ramp... you accelerate lightly from light to ramp, get up to 30...where you'll be in 6th (top) gear... then punch it on the straight of the ramp to get up to merge speed.
It will take you 3.8 seconds to get from 30 to 50.
Versus a model 3 AWD which will do the same in 1.5 seconds.
I'm looking forward to the P3 30-50, but you don't have to cherry pick your data to make it look better.
No one would be in top gear at 30mph unless you had it in comfort mode and even still I don't know.
In addition, if you had the dual clutch in manual mode you would be in second gear already.
I understand your point though, that in most situations you have to wait to downshift and that time can be an eternity for short bursts of speed.
It's pretty common for high powered ICE cars with any sort of automatic shifting to seek highest gear quickly for EPA/CAFE purposes.
If you're in comfort mode.
Edmunds GT-R review said:In automatic mode, the transmission just can't wait to get you into 6th gear. Under light acceleration, you'll be in 6th by like 30 mph. I did an experiment in our parking garage over a span of about 100 feet -- I went 0-18 mph, and I was in 4th gear by the end.
If
Because of compliance. If you have a GTR in comfort mode you're doing it wrong. This scenario simply doesn't happen unless you want it to. How do I know? I have a dual clutch transmission. When does it go into top gear? When I'm in comfort mode.
Comfort mode is a suspension, not engine, setting on the GT-R... so again... what the heck are you talking about?
Are you trying to invent some kind of imaginary 'chill' mode for the GT-R?
Again, there's no such thing as "comfort mode" for the GT-R transmission. It's a suspension setting that doesn't change shift behavior at all.
that's why there's a picture of a shock above the switch.
Edit: Upon further thinking I was crazy, a quick google search proved you are the one who will say anything just to be right
View media item 118887
... what?
Your picture in no way contradicts what I said- nor supports what you claim.
On the contrary, it shows exactly what I told you
There's a picture of a shock absorber above COMF.
because that's a suspension setting and not a transmission setting
The actual text also mentions you'll be in 6th before 30 in "save" (the snow mode).
The Edmonds review I provided mentions you are in 6th at 30 even in normal mode.
As in the mode the car is normally driven in.
I'd suggest you quit while you're behind, but...too late
This is what you do, focus on some pedantic reasoning
, but to the LEFT of the suspension switch there is a TRANSMISSION switch, which lets you put the car in R mode, which would never upshift to sixth at 30 mph.
That's how people NORMALLY drive GTRs
No more annoying early upshifts. I personally hate that the car lugs around town in 6th gear at 22 mph, it's ridiculous
You got Pwned
no, I focus on you being factually wrong but desperately flailing about not to be.
Really? Can you cite the actual ECU shift tables for R mode or are you just making stuff up again?
Nope.
The GT-Rs aggressively EPA-minded shifts has been a well known issue... to the point when custom tuners ask "what would you like to see us be able to change" such as here-
EcuTek - Let's talk shift points - Engine
The very first reply is:
"Don't want to be in 6th gear at 30mph lugging around. "
Another post
" My car gets to 6th at 34mph"
That's real world GT-R owners (unlike yourself) talking about real life driving a real life GT-R.
You keep using that word.
I do not think it means what you think it means
Where are the goal posts now? What kind of qualifiers and evidence do I need?
You are still Pwned and now you are getting desperate.
This metric can be evidenced by how quickly you find esoteric web references to prove your point.
You are wrong if you say the Nissan GTR takes 3.8s to go 30-50. You are dead wrong. If you have to add all these qualifiers then you're just equivocating.
Car and Driver said:Top gear, 30-50 mph: 3.8 sec
Top gear, 50-70 mph: 3.1 sec
nah man, I said those tests were from top gear
, and you continued down your meandering path of rationalization
and you are good with all your references and all that.
But they're always strawman arguments and the goalposts always move.
But you are still wrong. A GTR doesn't take 3.8s to go 30-50, unless you're in top gear and also in normal mode.
Therefore it doesn't take 3.8s to go 30-50.[
you're still wrong
I know the current political climate might make you think otherwise, but you repeating a lie doesn't make it true man.
Dude you're still wrong. You need a qualifier every time, now the qualifier is that it's the "default" of the car.
And on top of that you have to be "lightly accelerating" to 30 mph at which point you will see how fast it will possibly go.
So in "normal" mode, if you are "lightly accelerating", and then it "shifts to top gear" while you are lightly accelerating, at which point you decide to floor it, which you also say is the most typical use case, then it takes 3.8s to go 30-50.
You are using the worst case for performance, top gear in normal mode, to say that's how fast it goes.
But that's not how fast it goes. All I have to do to make that fact invalid is to floor it before 30 mph.
Your problem is you have too many facts that obscure the debate.
