AlanSubie4Life
Efficiency Obsessed Member
Sorry man. Hard to get a good read on it with just two significant digits...maybe another time when you have more than 100 miles remaining, we can get a better estimate.
This calculates out to 216Wh/rmi, but it is only two significant digits. So it could be off by a lot.
Thanks for the pictures...maybe another one some other time...
EDIT: No need for the lifetime Wh/mi for this calculation. Just those three other numbers, and they all should have three digits. Set display to miles, make sure you have a good charge, pull up that energy screen, make sure it is not set to “instant range,” and take a picture - that’s all that is needed.
@Wreckless316
I should add the following caveats: 1) Probably best to choose a 30-mile averaging interval as there will be the least variation on the projected range and efficiency so any "lag" in updating the numbers is of minimal impact. (You had this.)
2) Setting the units to km gives even better resolution.
3) Not ideal to do this after a large regen event, because rated miles are not instantly added back during regen events. That would result in potential error (depending on how things are implemented). So ideally you do this picture when you've been at positive consumption for the last few miles.
Summary:
Conditions:
1) Charge greater than 50-60% to maximize chance of 3 significant digits on all numbers
2) Set units to km if desired for better accuracy.
3) Choose 30-mile interval (or longest km interval), Using "Average Range", not "Instant Range"
4) Avoid recent large regen events which would have added rated miles.
5) Projected range needs to be less than 999 of course.
Numbers (all captured in the same picture at the same time):
1) Rated miles/km
2) Avg Wh/mi on left side of Energy Consumption screen
3) Projected Range in miles on right side of Energy Consumption Screen
Charging Constant = Avg Wh/mi (on left side of graph) * Projected Range (right side of graph) / Rated Miles (or km if km being used)
