Range on Long Road Trips
Discussion in 'Model Y' started by tjgunc, Feb 8, 2021.
Tags:
Do you experience any buyer's remorse with your tesla purchase due to take issues?
  1. Yes
  2. No
Results are only viewable after voting.
  1. Puma2020
    Puma2020 Member
    New Hampshire
    The road you are traveling on and the weather (headwinds & temperature) make a big difference whether you are driving ICE or EV.
    In the winter, cold air is more dense, requiring more energy to push through it. You also may be using stickier tires for better traction.
    Speed makes a huge difference. A long time ago, I was moving from Boston to Maryland. I had made that trip many times in my RX-4. I always had to stop around Cherry Hill, NJ to refuel. The fact that Big John's (rated best Philly cheesesteak 10+ years in a row) was also there simply a bonus. When I drove the u-haul and my girlfriend followed in my RX-4, I made the usual stop. On this trip we averaged around 60 mph, instead of my usual 75 due to the u-haul truck. My car had over a 1/4 of a tank left. I was amazed. It was getting around 35 mpg instead of the usual 28mpg. Just from the reduced speed.
    I found this chart that I think provides a good visual representation of what speed does to a model 3. The Y would have similar or maybe slightly worse values.
  2. Brian-MS90D
    Brian-MS90D Member
    Cincinnati, OH
    @jsight and others, you understand that Tesla is legally not allowed to state or promote any range other than the EPA range, correct? You are asking them to do something that your elected legislature has outlawed.
    Your complaint should be towards the US government, not Tesla.
  3. mk677
    mk677 Member
    jacksonville fl
    having made a similar trip in a model S all I can say is that you haven't grasped the nuances of driving an EV. first off forget about speed limits. the sweet spot between getting there faster and needing to charge longer for me is 70-75 MPH. then you have to account for the very long upgrades and headwinds going west towards the front range of the rockies. running the car down to 4% or charging to 100% is not an issue as long as you charge it up or run it down ASAP , letting it sit at that SOC level is a problem. enjoy your car, enjoy the road trips and as you gain experience with the car's nuances you will have less anxieties.
  4. jsight
    jsight Member
    Charleston
    That's definitely not true. Tesla has even derated their own range estimates at times. But I don't even want them to do that, I'd just like to see the 3 & Y upgraded to have batteries as large as the Mach-E, and keep the estimates approximately the same. This whole issue would go away and the new mileages would be vastly higher than they are now.
    They should seriously start working on new battery tech to do this right now. Maybe slightly increase cell length and more than double their diameter or something.
  5. VeganDiver
    VeganDiver Member
    Los angeles
    This is the reason I’d choose to view percentage over miles. In my old car (clarity) it would estimate your range based on you past 30 miles of driving efficiency. This made the displayed range vary wildly and was completely useless in my opinion. I.e. To estimate how long till I needed to stop at a charger, I’d need to try to adjust for road conditions from miles I’d driven on previous days and what my expected conditions were ahead. Tesla has it right here... it just gives you the rated range and you adjust by your upcoming road conditions, no guessing involved. I like to display miles in the Tesla because you get an extra significant digit in the display.
  6. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    I did some checks on EPA estimated efficiency * EPA estimated distance compared to measured efficiency * measured distance to come up with the EPA estimated battery capacities for each vehicle. As you can see from the cells highlighted in red, the EPA's estimate of Tesla's battery capacities far exceeds the advertised/known battery capacities by at least 10%. For example, using the EPA's numbers, the Model 3 Performance has a battery capacity of 89.9 kWh. The S & X have capacities of 114.1 and 114.8 kWh respectively.
    So my question is: how does this happen? Some of the non-Teslas also have proud EPA capacities, but to a lesser extent.
  7. mark95476
    mark95476 Member
    Bay Area CA
    The only "real-life" test that I think is applicable for me is my own use. I've had a Tesla for ~7 months and I think it's getting the rated EPA range or better. I generally drive a bit faster than normal and on routes that should make an EV suffer (twisty mountain roads).
    EPA (or whatever standard) range is a stick people can use to compare vehicles, but that's about it.
    I watch Bjorn on YouTube. He performs many tests, including 90km/h and 120km/h range and efficiency tests. He generally needs to go out on remote freeways at off-hours so he doesn't get slowed down by traffic too badly. This is almost completely artificial and not real-life at all, but is the only way to get somewhat consistent results.
    I live in an urban area and generally drive when others are driving, though I try to avoid rush hours. I can't avoid traffic, busy parking lots, surface streets, and there are intersections with stop signs and lights everywhere. I think I looked at this a long time ago with my gasser when traffic was heavier, but my average speed is ~25mp/h over a normal day.
    I plan on traveling and taking long road trips in the future, but that's <1% of the driving I do now. I've taken maybe one day trip over 100 miles in a day in the past year. The Tesla might get bad range and efficiency when I'm going 85+ mp/h, but people have figure this out already and Superchargers are common and expanding so I'm not worried.
  8. Brian-MS90D
    Brian-MS90D Member
    Cincinnati, OH
    When did Tesla do that?
    In layman's terms, in almost all cases the auto manufacturers use EPA method for rating. And whether it's ICE or EV, everyone knows the EPA is not accurate. Again, I propose that the issue is not a Tesla (or EV) problem at all.
    "In government and policy circles, it's well known that the EPA's fuel economy figures are too optimistic, but changing the system to more closely reflect real-world averages would mean lowering the bar on all the measurements of the current state of fuel efficiency on the American highway, and no one is eager to admit that we really haven't come as far in fuel-efficiency gains as it seems."
    Here's Why Real-World MPG Doesn't Match EPA Ratings | Edmunds
  9. jsight
    jsight Member
    Charleston
    The original Model 3 RWD was a bit understated. This table is somewhat helpful: Teslike.com
    There were a number of articles about it at the time: Why Did Tesla Ask US EPA To Downgrade Model 3 Range Rating To 310 Miles (From 334 Miles)? Was It Due To Expected Power Draw Of Autonomous Driving System?
    Porsche has done something similar.
    Also, the EPA updates its standards from time to time. The most recent update was in 2017, but a larger one was back in 2008: 2017 Ratings Changes
  10. threeputts
    threeputts Member
    Minnesota
    Here's another more "real world" test from about a year ago. They charge a bunch of EVs to full, let them sit overnight, then drive them on the highway until they are very low, then drive them literally until the come to a stop. None of the cars made it to their rated range under these conditions. A Kia came closest with a 90% result, followed by Nissan at 87% and Audi with 81%. The Tesla of the group, a LR M3, achieved only 78% of it's rated range - but the Jaguar (76%) and Benz (75%) did even worse. Remember they all lost about 4% overnight and unfortunately they didn't bother to charge them back to 100% before they set off.
    It's actually an amusing video. Also informative as they find out how far each car can actually go with the displayed battery remaining reaches 0.
  11. mark95476
    mark95476 Member
    Bay Area CA
    I collected some "real world" data which has me driving to work, and up and down my local mountains. It doesn't include my drive back home, but that's slow so it only reduces average consumption (and increases range).
    2020 EPA combined for MY LR AWD is 28 kWh/100 miles = 280 Wh/mi
    - The first picture was taken at the top of my local mountains (after ~2500 ft climb over ~7 miles).
    Stats: 943 Wh/mi avg over the previous 5 miles and 474 Wh/mi avg after 21.5 miles
    - The second picture is at the bottom of the mountain (back to ~sea level). I gained about 3% SoC from regen.
    Stats: 248 Wh/mi after 36.4 miles
  12. FatherTo1
    FatherTo1 Member
    #52 FatherTo1, Feb 25, 2021
    I haven’’t driven other EVs but I don’’t find Tesla’’s range estimates exaggerated at all. Back in 2019, MotorTrend confirmed the 370-mile Model S completed the 359-mile distance from Fremont to LA, with 11% (41 miles) of range remaining. They exceeded range estimates during the trip with two people in the car, AC on, and 65-70 MPH.
    I also routinely exceed the EPA ratings on our Raven Model S Standard Range. With my 72.5 kWh usable capacity, I need to average 254 Wh/m to get rated range but I actually use 230 Wh/m at freeway speed and beat EPA range. Below is a snapshot two weeks ago where I travelled almost 90 miles and averaged better than EPA ratings, even at 65 MPH.
    All that said, I don’t intend to drive down to zero but I have gone down as far as 4% and traveled 245 miles. This equates to 90% efficiency for my 285-mile rated range. That is plenty reasonable in the real world for me.
    In cold weather, all EVs will experience significant range loss. If you’’re seeing or reading a disproportionate amount of Teslas missing range targets, I suspect the majority of them are also riding on larger wheels, which do incur a 10-12% hit to range. Our Model S came with 21s and my range immediately improved by 12.5% when I downsized to 19”” wheels. The Mach-e seems to use smaller wheel and tire combos and I’’m sure that’’s helping it hit range estimates, along with the larger reserve capacity.
    Admittedly, I haven’t kept up with the Mach-e and other EV entries as I still don’’t see a truly compelling competitor to Tesla yet, in terms of style, performance, battery tech, and charging infrastructure. A lot of automakers are still playing catch up but competition is fierce and everyone is learning fast. It is great that other EV models are designed to consistently achieve their rated range, that only bodes well to lure in new buyers and increase adoption. From my experience, Tesla’’s range estimates have been pretty accurate (except in really cold temps).
  13. JAM3S
    JAM3S Member
    Ottawa
    THIS.
    I think this is the most on point suggestion from my limited EV ownership experience to date (BMW i3). My ICE car (BMW M3) is a naturally aspirated V8 that is for an ICE car bad in the winter, losing about 25% of its range in the cold. She gets thirsty. But as we know a Canadian cold EV is likely to lose closer to 45% of its fair weather range.
    An EPA duality rating for "Fair" vs "Cold" weather will be a great direction for the industry to go.
  14. kadify
    kadify Member
    colorado
    I just went on a road trip from CO to NY in my MYP. Going 80 mph using autopilot, we averaged around 195-203 miles on a full charge in roughly 10-20 degree weather. I think if it had been warmer we would have been able to go further but I'm also not upset with the range. After 200 miles (roughly 3 hours of driving) we were ready to get out and stretch our legs, let the dogs go to the bathroom, etc. We would have naturally stopped around every 200 miles anyway. The only inconvenience we experienced was having to charge 45 minutes to recharge. Our navigation was suggesting we do fewer stops but charge closer to full at each stop which meant we quickly were at 70% charge from ~4-10% charge but then we inched up to 90-95%. We got really good at beach buggy racing as a result xD
  15. Wannabeskibum
    Wannabeskibum Member
    Waterloo
    To the OP. On the bright side that was a really good week in JH with a ton of snow. BTW did you have ski box on top?
    I understand your frustration as I drive that stretch of I-80 quite a bit in the winter. Interstate speeds in EVs are tough and when you combine the constant 50 mph headwind and crosswind that Cheyenne to Rawlins gets in winter, it is horrible. That is really the worst stretch of road I know of in the US by far. We have a Model 3 and our ski car is a E400 wagon*. We used to have a big SUV but the headwind and crosswinds in that area made it crazy, even with winter tires.
    I am holding out for the 500+ Cybertruck to replace our ski wagon, even then it can be tough as since that road closes so much in winter going the northern route is sparse of chargers.
    *Frustrations abound as on the morning before we left on our trip (Feb 5th) I took our wagon in for a routine A service. They did some recall and apparently destroyed the electrical system in the car. They *graciously* offered us a car from Enterprise their only SUV smelled like a ashtray's A hole so the four of us drove up through a blizzard in a Ford Fusion, AWD with no snow tires and no ski box. 800 miles of the 940 mile trip was snow and ice covered. Still with a loaner and heading back west in a week /sigh.
  16. Wannabeskibum
    Waterloo
  17. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    How hard is it for owners to understand that above about 50 mph, the faster you drive the less range you can expect.
    Head winds, elevation changes, snow, rain, heavy loads, pulling a trailer, not driving smoothly etc will all reduce range.
    Your display has a constant usage display. You can easily see what range you can expect at any given condition. If you see you will not be making your next stop, then simply slow down until you learn what speed you need to maintain to make it.
    Most of these range posts seem to come when someone else is a passenger and you do not want to deal with them complaining about stopping for juice.
