I just finished a cross Canada road trip in my M3 RWD and previously a road trip to and from SE Arizona.Realistically, what is the range of a model 3 standard battery single engine at summer highway speeds. Can you easily get 200 miles without too much anxiety?
I do long drives through Arizona all the time in my LFP M3. I find that it really helps to have a CCS1 adapter, to fill in the gaps between TSC stations on the freeway. For example; There's an TSC station in Deming NM and an EA station at the Walmart in Deming NM. There's an EA station at the Lordsburg Chevron, and a TSC station in Wilcox AZ and a EA station at the Walmart in Benson AZ. So if you want to drive from Tucson to Deming, and back again. the EA stations help fill in the gaps. Our winter home is in Portal AZ and the EA stations are very convenient for us. especially for shopping. From Portal to Winslow, via Hwy 60 the EA stations really help as well.I would refer to the many posts about range from existing owners, since they may contain real numbers.
My answer is: maybe, but maybe not.
If "highway speeds" means 75mph, probably the answer is no. If there's a headwind, very unlikely. If it's really, really hot... you'll be using A/C but so will your battery.
If the reason you're asking is because you have a very specific 200 mile commute in mind that you want to make without stopping at a fast-DC charger, then I would say this is a misguided goal. Just stop for charging... it'll probably only be 15 minutes at the charger.
If the reason you're asking is because you occasionally make a 200 mile drive through the Arizona desert and there are no chargers on that route, I'd say it's probably a really bad idea (dangerous even).
If the reason you're asking is because you or someone you know is trying to decide between a standard range and long range Model 3 - do consider degradation... they'll both have less range in 5 years than they do when brand new.
I personally don't worry about "can I get 200 miles" out of my M3LR... I just get in and let the navigation point the way. If that means stopping for fast-DC charging then the car will tell you.
Depends on how fast you drive, the weather (wind, rain), and how much HVAC you use. But you have to drive rather uneconomically to run out after less than 200 miles on a 272 rated mile car.Realistically, what is the range of a model 3 standard battery single engine at summer highway speeds. Can you easily get 200 miles without too much anxiety?
I bought a 2019 M3 SR+ in March 2019. 100% charge was 240 90% was 216. Now I'm lucky if I get 200 at 90%. I live on Long Island east of NYC. Land is generally flat. Temperature as you can see from MCU is 79 degrees F and I set the air to 79 F. Plenty cold, If you look at that stats in the lower left I'm getting about 5 miles per kwh. My advice is don't drive like an idiot (50-60 is fine unless you're delivering a baby, etc). Coast to red lights, don't accelerate fast, if you hit a hill coast and let gravity regen the batteries, hit the accelerator on the upswing. This will ensure you get the most bang for the electron so you need SC less. BTW I pay .26/kwh charging at home. SC near me ar .44/kwh during peak. Off peak is 1-4AM!!! .10/kwh. So if you need to SC do it in the dead of nightRealistically, what is the range of a model 3 standard battery single engine at summer highway speeds. Can you easily get 200 miles without too much anxiety?
Deming to Tucson is 218 miles via I10. The most convenient charging stop to get there is the lordsburg NM EA Station, as the Wilcox SC station is too close to Tucson. I've used the Lordsburg EA station many times and always got reasonable charging speeds. Occasionally there was a downed charger, so check ahead using plugshare. I've done lots of 2000 mile plus EV road trips and having a CCS1 adapter is very useful IMHO.Just to add that you probably will never need to use a third party DC fast charger or a CCS adapter, unless you're really off the beaten path. They're absolutely slow and unreliable anyway and I would never put myself in a position where I needed to use one. Even the example above from Tucson to Deming is only 133 miles, so you wouldn't use anything but a Tesla supercharger, even with a RWD (unless you had some awful combination like a roof rack loaded going 90 mph up a mountain pass).
Glad you decided on the long range, my wife and I have taken six trips so far totaling 15,000 miles and never had any issues or range anxiety.
Typical normal speeds on Arizona highways are around 80-85mph. So no, you will not be able to do 200 miles with very little anxiety.
Specifically with a 60.4kWh degradation threshold, you’ll need to do:
60.4kWh*0.955/200mi = 288Wh/mi
That’s very unlikely to happen at 80-85mph. (Though RWD does help get closer.) And that’s to 0% displayed (so 4.5%)!
To a more reasonable 5% displayed (car not telling you to slow down, which is annoying), you need:
60.4kWh*0.95*0.955/200mi = 274Wh/mi
After 5 years and 10% capacity loss you’ll need to do:
60.4kWh*0.9*0.95*0.955/200mi = 247Wh/mi
247Wh/mi is most definitely not happening at 80mph! Unless you have a massive consistent tailwind (possible in the desert) - but that could be a headwind too.
There will be a lot of anxiety.
It’s hard (though possible) to do 200 miles in an LR (need to do 320Wh/mi or so which is definitely possible). Definitely have easily done it on downhill stretches, but rare. Usually supercharger positioning makes it not something you’d ever get to.
Yes, as I said, it is definitely possible. Not the norm though. Depends a lot on the type of travel. You usually won’t be doing that on the wide open interstate with no traffic, for example, traveling at 80-85mph, which is very typical in SW US with low population density.LR can definetly do 200 miles
Here you go, completely full to completely empty at 70mph:Realistically, what is the range of a model 3 standard battery single engine at summer highway speeds. Can you easily get 200 miles without too much anxiety?
