Often, when I approach the car from the rear, the manual hatch button underneath the hatch will not operate. Is the car supposed to auto present the door handles and unlock the rear hatch if you are standing behind the car?
When you approach from directly behind, the door handles do not present.
However, when you push the manual button (on my car at least) the trunk unlatches and opens and the handles present (if set to present on unlocking). There is a sensor at the rear for the key fob.
I thought I was clear.I have mine set to present the door handles as I approach. If there is a sensor in the rear, either mine is not working or there is a setting that I am not familiar with. If I approach from the rear my door handles do not present, why would the trunk unlock?
There is a sensor at the rear which, if it detects a key, will allow you to hit the manual trunk latch on the vehicle allowing you to open the hatch. Once the trunk is latch is operated, the door handles are unlocked and, if set to auto-present, they present themselves.
The handles will not auto present from the rear sensor until you operate the manual latch.
I think if you have manual trunk, you must unlock car first.
Interesting... the online manual says
"Press the switch located under the exterior handle (depending on date of manufacture and options selected at time of purchase, some Model S vehicles require you to first unlock Model S)."
So, either your rear sensor is not working, or there is a possibility that's the way it was designed.
I think if you have manual trunk, you must unlock car first. @SDRick looks like he has loaded P90D so I would get things checked.
just fyi here's my observation with my early Dec 2015 70D, slightly different than mentioned above: I have the power liftgate, auto-present door handles = on, door unlock mode = driver, walk-away door lock = on, unlock on park = off (in case any of those settings make a difference)There is a sensor at the rear which, if it detects a key, will allow you to hit the manual trunk latch on the vehicle allowing you to open the hatch. Once the trunk is latch is operated, the door handles are unlocked and, if set to auto-present, they present themselves.
Hmmm. I do have door unlock mode = all. I wonder if that makes a difference. No time to check now.just fyi here's my observation with my early Dec 2015 70D, slightly different than mentioned above: I have the power liftgate, auto-present door handles = on, door unlock mode = driver, walk-away door lock = on, unlock on park = off (in case any of those settings make a difference)
with key fob in pocket, if I approach from the rear and walk right up to the trunk, tapping the manual release latch on the trunk opens the trunk. But all the door handles remain retracted. in fact, all the doors remain locked. For example if after opening the trunk, I leave the fob in the trunk and walk to the front of the car, the driver's door and passenger doors remain locked - tapping them will not pop them out.
to the OP, perhaps you have some problem with the rear fob sensor in your car?
I just tested that and now with unlock mode = all, the door handles all pop out when approaching from the rear and manually opening the trunk. So yes that setting makes a difference!Hmmm. I do have door unlock mode = all. I wonder if that makes a difference. No time to check now.
So for you, having the door unlock on either "all" or "driver only" both work? For me, neither of those work... And by "work" I mean both settings allow you to unlock the trunk without first having to unlock the passenger doors.I just tested that and now with unlock mode = all, the door handles all pop out when approaching from the rear and manually opening the trunk. So yes that setting makes a difference!
yes, for me approaching the car from the rear with fob in pocket always allows me to open the power liftgate/trunk without first unlocking the passenger doors. Normally I have Door Unlock Mode = Driver, in which case opening the trunk in this manner doesn't auto-present any handles. With Door Unlock Mode = All, opening the trunk causes all the door handles to pop out. In either case, I do nothing manually to unlock any doors, just walk up to the car and pull on the trunk latch. Re: @golfnut's observation above, in my case I always have my phone and fob in different pockets so I don't know if that's a factor.So for you, having the door unlock on either "all" or "driver only" both work? For me, neither of those work... And by "work" I mean both settings allow you to unlock the trunk without first having to unlock the passenger doors.
This is exactly the case for me, except I have an April 2015 85, with power liftgate.just fyi here's my observation with my early Dec 2015 70D, slightly different than mentioned above: I have the power liftgate, auto-present door handles = on, door unlock mode = driver, walk-away door lock = on, unlock on park = off (in case any of those settings make a difference)
I also keep the keyfob and my phone in separate packets, and simply walking to the trunk from the rear and clicking the button on the trunk works to open it for me.The only time it has failed to work for me was when I had my fob in my pocket next to my phone. I usually have them in separate pockets. Not sure if that made the difference, but it has worked every other time. Maybe something to test every once n a while.
@Julesp313 I thought you had a manual hatch. As mentioned before, I understand that you have to unlock the doors to open the hatch in all manual installations.So for you, having the door unlock on either "all" or "driver only" both work? For me, neither of those work... And by "work" I mean both settings allow you to unlock the trunk without first having to unlock the passenger doors.
I do have a manual trunk - but the guidance in the online manual doesn't state that the manual trunk won't open unless you unlock the doors - except it DOES state that under the guise of "some dates of manufacture and some options" which is rather vague, if you ask me!@Julesp313 I thought you had a manual hatch. As mentioned before, I understand that you have to unlock the doors to open the hatch in all manual installations.
