SDRick, The fob antenna was about $ 25.00 Installation took about 30-45 minutes. I played around with where to run my wire, up the headliner or down and along the door sills. Settled on door sill areas. Once you get past the rear door sill, you must tuck the wire along the trim and behind the upper seat belt anchor point and around the parcel shelf plastic bracket. I know someone else on TMC that did it too. We both recommend you use shield 1 pair cable. The front door fob antenna is at the end of the dash (on both sides) attached to the sort-of-triangular trim at the end of the dash. (The door panels covers this trim when the door is closed.) You simply tap into the two leads to attach your new antenna. There may be polarity, so make sure you stick with white-to-white and black-to-black. Also recommend you use some sort of quick connector for your new shield wire when you attach it to the white and black lead at the existing fob antenna.
